skip shift eliminator
Old Sep 11, 2004 | 07:09 PM
motion l-88's Avatar
motion l-88
Default skip shift eliminator
just wondering if anyone install one of these yet! would like to here some feed back. found it on westcoast corvettes. they say simple plug in to eliminate that annoying 1st to 4th shift thanks
Old Sep 11, 2004 | 07:50 PM
Torqued84's Avatar
Torqued84
Popular mod. This was the first thing I did when I bought my C-5. Works great, no problems. I got mine from Mid America but one's probably as good as the other. You might also think about getting the Steering Column Lock Bypass too.
Old Sep 11, 2004 | 08:04 PM
Nitro Junkie's Avatar
Nitro Junkie
Bought mine from a forum member in the C5 Parts For Sale section for $15. Took 5 minutes to install. Great mod.
Old Sep 11, 2004 | 08:53 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
If you have LS1 Edit, you can use that to turn off the skip shift feature. Or, have your dyno-tuner do it for you. Mine was turned off this way.
Old Sep 11, 2004 | 09:42 PM
andy82's Avatar
andy82
2017 C7 of Year Finalist
Installed it 1 day after C5 delivery. With an MN6 I want to be in control, not the Puter.
Old Sep 12, 2004 | 04:41 AM
markcz's Avatar
markcz
Best $20 I ever spent
Old Sep 12, 2004 | 07:50 AM
DrValidus's Avatar
DrValidus
Default do it
If this is a daily driver for you, it's almost a must! I did it and had no problems. The 1-4 was really, really annoying.
Old Sep 12, 2004 | 11:56 AM
motion l-88
thank everyone on ther advice! also noticed on same web site a simple peel and stick stainless exhaust plate, any in put. 2004 msg conv. just turn 1000 miles brougt into dealer friday for recall on lock.
Old Sep 12, 2004 | 11:58 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
bought mine from a forum member as well.
great cheap mod, and took about 5 minutes to install.
Old Sep 13, 2004 | 12:09 AM
dekidex's Avatar
dekidex
Default skip what?....
What's that skip shift all about?how is it suposed to be good for you?i don't get it....can someone explain this to me..?i own a A4 but was allways curious as what to people reffer to with the skip shift.....
Old Sep 13, 2004 | 12:18 AM
DanielW's Avatar
DanielW
the skipshift forces you to go from 1st to 4th gear under certain driving conditions in a manual tranny. it was implemented to get a better MPG rating on the vettes, and avoid a gas guzzling tax.
To skip shift eliminator
