code 10 pcm
Old Sep 11, 2004 | 08:45 PM
Jim D's Avatar
Jim D
Default code 10 pcm
I have this code on my 99 , this is the second time in about a month, any idea's , thanks Jim.
Old Sep 12, 2004 | 10:57 AM
Blow Torch's Avatar
Blow Torch
Jim
You will need to write down the specific code it is giving you. Example; I am getting a P0161 H C now. Find out the exact code it is giving, and post it on the forum to see if someone knows what it is for. You can also use the serch funtion for info. on that code.
Then again You can just get a service manual that list the codes, which is what I may wind up doing if I keep throwing codes.
Old Sep 12, 2004 | 12:35 PM
SERIOUS RACER's Avatar
SERIOUS RACER
ITS THE MASS AIRFLOW SENSOR JUST CALLED ON IT
Old Sep 13, 2004 | 07:20 AM
C5 Frederik's Avatar
C5 Frederik
This is no code, this is the headline you show. See first codes belonging to that headline:
10-PCM - Power train Control Module
P0101 Mass Air Flow (MAF) System Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0107 Manifold Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Pressure (MAP) Sensor Circuit High Voltage
P0112 Intake Air Temp (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temp (IAT) Sensor Circuit High Voltage
P0117 Engine Coolant Temp (ECT) Sensor Low Voltage
Frederik
To code 10 pcm
