CODE.... B0333 Outside Air temp sensor open
Old Sep 11, 2004 | 10:42 PM
dddz06's Avatar
dddz06
Default CODE.... B0333 Outside Air temp sensor open
How Can I Fix This
Old Sep 11, 2004 | 10:51 PM
msghuff's Avatar
msghuff
Originally Posted by dddz06
How Can I Fix This
you just did a cam swap right? check the front right of your rad shroud to see if you pluged the sensor back in or if you damaged it removing the shroud.
