ecu problems (service: ABS,traction control,reduce engine power
Old Sep 13, 2004 | 02:48 AM
[ Ls1 ]'s Avatar
[ Ls1 ]
Default ecu problems (service: ABS,traction control,reduce engine power
well ive heard of others having this problem before...however i cannot seem to find these threads...this problem seems to arise most when i drive for a distance then park for a short period...upon restarting the car the service codes will come up on the display, however the car seems to run fine...my plans were to have this taken care of by chevrolet, when i take my c5 in for the column lock bypass...should i take any precautions before taking in the vehicle and is this the best course(ive heard some issues with the factory bypass install)...any advice is always greatly appreciated
