a flat w/the run flat!
Old Sep 13, 2004 | 06:51 PM
not08crmanymore's Avatar
not08crmanymore
Default a flat w/the run flat!
can a run flat g/y tire be plugged?do i need to get a new one?do i need to put air in the tire at all before repair?i went to drive it and heard a rattle in the rim...thanks for the info got tire patched.looking for new set.thanks for the help..
Old Sep 13, 2004 | 07:13 PM
JBH's Avatar
JBH
Yes, a Goodyear and a Michelin can be repaired. Not sure about the other brands.
Old Sep 13, 2004 | 09:30 PM
eaa1964's Avatar
eaa1964
yes. they were successful in plugging a partial side wall nail hole.
Old Sep 13, 2004 | 09:40 PM
RWhite's Avatar
RWhite
If it still is in the mileage warranty (so much thread left) Goodyear will patch it free (an inside patch, not a plug).
Old Sep 14, 2004 | 08:42 AM
C5GIVPilot's Avatar
C5GIVPilot
I plugged a nail hole in my Goodyear run flats and drove on it for 10k, (until the tires needed replaced). It never leaked. I Coated the plug with rubber cement and brought the tire up to pressure before the repair.
Old Sep 14, 2004 | 09:20 AM
Mr. Jones's Avatar
Mr. Jones
goodyr repaired a slow leak (run flat) for me at about 5000mi. they did not plug it. make sure they have the right equipment not to damage the rim.
Old Sep 14, 2004 | 10:04 PM
not08crmanymore
Default tire fixed
got the tire fixed.i need new ones now.found out the one that went flat was patched before!thanks for the help.
Old Sep 15, 2004 | 09:52 AM
ZO6vettepilot's Avatar
ZO6vettepilot
Originally Posted by jessem
can a run flat g/y tire be plugged?do i need to get a new one?do i need to put air in the tire at all before repair?i went to drive it and heard a rattle in the rim...thanks for the info.
The Goodyear EMT is rated as follows: Rated to travel 200 miles in 73 degree weather at 55 MPH with the car at gross Weight. The tire can be repaired after a runflat incident up to 50 miles at 55 MPH.
Michelin Pilot Sport A/S Zero Pressure tires are rated for 50 miles at 55 MPH and also can be repaired after a runflat incident.
THe Firestone SZ50EP RFT and the Yokohama AVS Sport Run-Flat tires are rated to travel up to 50 miles at 55 MPH in a run-flat state, but cannot be repaired after a runflat incident.
zo6vettepilot
Old Sep 16, 2004 | 10:43 PM
sunshine's Avatar
sunshine
I had a rock 1-1/2"x 1" go thru my tread and into the rear tire. The origional g/y were tired (31k), but Costco in Prescott put a patch on it and I drove it 60+ miles back to Phoenix on I-17, and for the next week until my new Michelins came in.
Old Sep 17, 2004 | 09:29 AM
not08crmanymore
Default delete
please delete theis thread,i don't know how to do that that!thanks again.
To a flat w/the run flat!
