need help with bleeding brakes
Old Sep 14, 2004 | 10:40 PM
97coupechuck's Avatar
97coupechuck
Default need help with bleeding brakes
put new calipers on my 97 coupe, bled the brakes forever with no luck. Still pulls and one tire locks up before another. Any tricks known out there? Chuck
Old Sep 15, 2004 | 12:38 AM
Richin Chicago's Avatar
Richin Chicago
Some questions. Are the new calipers on the front or all around? How is the brake pedal? Firm? is the brake fluid level holding steady or is it dropping?
Does the wheel really lock up or do you mean the ABS kicks in? If not see if you have any trouble codes.
http://www.stengel.net/diccodes.htm
Did you grease the caliper pins?
