DIY rear o2 simulators
Old Sep 16, 2004 | 12:48 PM
cjs27410's Avatar
cjs27410
Default DIY rear o2 simulators
Does anyone know which ohm resistor to use?
Old Sep 16, 2004 | 05:37 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
I'm not certain but I believe it's more than just a single value. Other components are involved.
Old Sep 16, 2004 | 06:13 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
not so easy... O2 sensors put out a signal between 0 (lean) and 1 (rich), when they warm up.
In the old days, you could fake it with a 555 timer and some minimal circuits, but with OBD-II, there are alot of checks for frequency of oscillation, etc...
Old Sep 17, 2004 | 12:00 PM
cjs27410's Avatar
cjs27410
I think:
The rear o2 sensors only signal that the cats are installed.
The front o2 sensors regulate the lean & rich mixture.
Old Sep 17, 2004 | 03:25 PM
SideStep's Avatar
SideStep
I think:
Correct, the rears are only for emissions, the fronts are for AF ratio management....
Old Sep 17, 2004 | 07:41 PM
dpd's Avatar
dpd
partially correct.rear o2's measure cat efficiency.they tell the ecm how well the cats are operating,but the voltages do change[they don't fluctuate like the fronts,but will cycle between .3-.6 millivolts]
Old Sep 20, 2004 | 10:28 AM
cjs27410's Avatar
cjs27410
I signed up for the GP on an HP tuner program. That will take care of it.
To DIY rear o2 simulators
