Idle issues..still :banghead: NEED HELP!!!!
Old Sep 18, 2004 | 05:21 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Idle issues..still :banghead: NEED HELP!!!!
Ok, back in April had the cam installed 224/222...car was tuned and ran great...a couple weeks later I added and aftermarket airbridge...no problems...drove to CI and back car ran great. Nothing else done to the car.
The problem I am having is at idle...sometimes right after startup and sometimes not until I drive it a ways....when I come to a stop the idle drops down and sometimes "hunts" between 750 and 200 bouncing up and down...sometimes it dies which is a real PITA There seems to be no real corelation between heat/ humidity etc. when it happens.
I have been back to the tuner and the car checks out fine.
To date I have changed plugs and wires (one wire was in fact going bad)
Removed the after market airbridge and went back to stock (seemed to cure the problem temporarily, like 2 hours )
I have cleaned the throttle body and air filter (Blackwing)
Oh yeah the TB was drilled at cam install time.
I have checked all connections so many times I am going
So....what I need to know...could this be a fuel problem??? It seems to me that if it was I would notice it other than at idle. It does have the stock fuel filter and pump. Currently I have 58K on it and I run Redline S-1 thru it pretty religiously.
Next could it be a faulty sensor?? Someone suggested that the MAT sensor could be bad giving it a wrong reading...
I have no F'ing idea at this point
Any thought suggestions or tips would be greatly appreciated.
*******REPEAT****Car was tuned perfectly...this occured AFTER I had the car for awhile so this has developed on its own.....which is what leads me to believe it has to be a fuel / air or sensor problem.
I have no reason to believe that if it was a tuning issue it wouldn't have been fixed...I am only considering asking to get it wiped and retuned to simply rule that out....this has got to be something simple I just don't want to throw money at the car in hopes that I get it
Old Sep 18, 2004 | 08:48 AM
MrEracer's Avatar
MrEracer
If your tuner cannot solve these problems with that small cam, get another tuner that knows what he is doing. Your problems are very common and there is nothing wrong with your hardware, wiring or sensors. You need to address the VE tables, AIR table, spark tables and idle settings. This can be done with HP Tuner or LS1Edit. You should also tune your WOT A/F ratio and L-Trims using the same tuning suite.
Shirl
SDRE
Old Sep 18, 2004 | 10:18 AM
pewter99's Avatar
pewter99
Ttt
Old Sep 18, 2004 | 12:05 PM
pewter99's Avatar
pewter99
again
Old Sep 18, 2004 | 12:42 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Shirl
SDRE
Old Sep 18, 2004 | 01:08 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Shirl
SDRE
Well said.
Old Sep 18, 2004 | 01:21 PM
pewter99's Avatar
pewter99
hmmm....I have not and will not say who did what...but I am considering getting a second opinion
Old Sep 18, 2004 | 08:19 PM
pewter99's Avatar
pewter99
Gonna call on Monday and see about having the program wiped and redone...maybe there is a glitch somewhere..car died on me twice today..........in my driveway
Old Sep 18, 2004 | 08:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had some VERY strange electrical problems a while back and solved them by cleaning my ground connections. Check out this post:
http://forums.corvetteforum.com/show...post1548248859
BC
Old Sep 18, 2004 | 11:28 PM
ScreaminDemon's Avatar
ScreaminDemon
This is common with drilled tb's, as mentions above. Being a 99', some 02 sensors wouldn't hurt either, they do get dirty and go bad causing your pcm to recalibrate, but that drilled tb is the first issue.
Old Sep 19, 2004 | 05:53 AM
pewter99's Avatar
pewter99
So do you think the 02 sensors could cause this problem??
How do I check them??
Old Sep 19, 2004 | 08:45 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
In the interest of Science, remove your blackwing (almost typed blackwang) and re-install your stock air filter... that could be one contributing factor as some cars dont like the blackwing. My car didnt like a boosted MAF so I know how those kind of things go...
Next, get a non drilled TB and install that and then take it to a tuner who can tune the car correctly.
Best of luck to you getting it fixed.. keep us posted.
VR
Old Sep 19, 2004 | 09:48 AM
pewter99's Avatar
pewter99
Well thats out...Blackwing has been on the car for 3 1/2 years and I do not have the stock system anymore.
Old Sep 20, 2004 | 04:32 AM
pewter99's Avatar
pewter99
TTT...its Monday
Old Sep 20, 2004 | 10:49 AM
yellowvette837's Avatar
yellowvette837
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
Old Sep 20, 2004 | 03:52 PM
Avanti's Avatar
Avanti
It would seem you have some worthwhile suggestions to start with, especially the throttle body issue. All the things you have done may have been fine until you made the final change and then things don't play well togethter... think typical desktop or notebook computer.
All the best.
Old Sep 20, 2004 | 04:03 PM
gojo's Avatar
gojo
Shirl
SDRE
Given there is no mechanical problem, I believe MrEracer is right. Your tune seems to be learning out. This happens when the tune is wrong to start with.
Your VE's are likely not right and is a must place to start. Also, plug the hole in the t.blade. Not a good sign if the tuner did it. It's not needed on a C5.
To Idle issues..still :banghead: NEED HELP!!!!
