The euros, whether clear or amber, blink just the clear or amber portion. The red portion is just for the brake light. This is assuming the proper wiring harness adapter is used which converts it to two single filament bulbs instead of one dual filament.
From: No more yankee my wankee, the Donger is tired!
Originally Posted by shnooks-formula1
I wanted to know if on the true euro versions do the amber and the clears blink when the turn signals are on..or does the red/amber only blink.
In europe, they have a wider plate, which means you no longer have reverse (backup) lights. This is why there is a clear.
When turning, only the amber should flash.
Now vendors in the US have made the harness for turn signals only, since we still have the reverse lights at the sides of the plate. So you can either choose the white versions and use amber bulbs (or clear and look ricey) or use the amber lenses.
