Please Help-broke Tranny....
Old Sep 22, 2004 | 01:54 PM
vettethret's Avatar
vettethret
Default Please Help-broke Tranny....
I am at a loss for words and hope that some more experienced guys could help me. Friday night I shifted hard from 1st to 2nd and thought I blew up the diff. The car has 3:90 gears with 387 rwhp and 367 rwtq, not alot of power compared to some. I just got a call from WCC and I broke the output shaft coming out of the tranny and basically need a new transmission! The car is an 04 with 12k miles. I am PISSED at this point. Is this common? I thought these cars were A LOT stronger than this? I don't know if GM will warranty this. I asked John the head mechanic with a ton of experience and he says he doesnt see it as a defective part. I snapped so hard it broke the diff case. How can blower guys with 600 rwhp not have this problem and my car on 20's does?
Old Sep 22, 2004 | 02:43 PM
vettethret's Avatar
vettethret
Ttt
Old Sep 22, 2004 | 03:04 PM
kromberg's Avatar
kromberg
The differential output of the C5 has always been a weak link, but I have not heard of one breaking less than a year old. Definatetly get it replaced under warrenty. If you buy the 300M harden output shaft, I am sure the dealership would not mind installing that one rather than another POS GM one.
Keith
Old Sep 22, 2004 | 03:30 PM
BigBlue's Avatar
BigBlue
Good luck getting it warrantied. Especially with new rear end gears. The 600hp guys are having this problem as well. The stock output shaft just can't take a lot of abuse.
Old Sep 22, 2004 | 03:43 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Sorry to hear about your tranny. ttt
Old Sep 22, 2004 | 04:17 PM
Patches's Avatar
Patches
Sorry to hear that. I'm not too surprised though considering your combo of the M12 with 3.90's puts my MM6 with 4.10's to shame when it comes to final drive ratios. Your 1st is 11.58 while 2nd is still a beefy 8.07. The SM rates the MM6 at 450 lb.ft.and the M12 at 400 lb.ft. With 20's and that torque multiplication, that's a lot shock for the output shaft and diff to absorb. The wind-up can be pretty severe. The stiff suspension has very little give as well. Below is a pic I snapped of a buddy's tranny output shaft when we pulled the drivetrain a couple of weeks ago.
Old Sep 22, 2004 | 04:34 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Good to see Mike finally had an opportunity to use his jack on his transmission! ('cause it worked well for me).
So Ed, are you going to assist in the re-install?
Old Sep 22, 2004 | 04:38 PM
vettethret's Avatar
vettethret
Keith
I thought the hardened output shaft was for the rear end? Is there any stronger replacement parts I can put in to avoid this again?
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
So you broke the output shaft on the transmission and it in turn broke the case on the rear diff? time for a DTE strut brace as well DTE brace
Old Sep 22, 2004 | 04:41 PM
vettethret's Avatar
vettethret
Will that help? Thanks guys for all the answers. This is one area I'm new in.
Old Sep 22, 2004 | 05:22 PM
Patches's Avatar
Patches
Definitely go for the DTE brace and the hardened diff output shaft. I don't think anyone has come out with a hardened tranny output shaft yet - at least, I haven't heard of one.
Best of luck on the repair.
Dan - yes, we are tenatively scheduled to reinstall on 10/2.
Old Sep 22, 2004 | 05:36 PM
The One's Avatar
The One
Sounds to me like events happened in reverse of what you were told. You probably broke the differential first, causing the casing to rotate in place and take out your tranny output shaft as a result. Don't ask how I know.
And yes, in this case a differential strut would've helped. May not have saved your differential, but would've saved the tranny for sure. I haven't had any breakage since installing one (not the DTE one, but the prototype of the first one on the market about 2.5 years ago.)
By the way, I did have my tranny rebuilt with a hardened main shaft. The 4.10s also have a hardened output shaft.
Good luck. Nasty breakage.
Old Sep 22, 2004 | 05:37 PM
T_Vert's Avatar
T_Vert
that is a nice jack where did you get that and how much?
Dave
Old Sep 22, 2004 | 05:49 PM
vettethret's Avatar
vettethret
Where did you get the hardened tranny shaft? Believe me, I will be ordering the DTE brace.
Old Sep 22, 2004 | 05:58 PM
RoadRebel's Avatar
RoadRebel
I have broken enough of those parts to be amillionare just in scrap metal.
The mainshaft can be replaced in your tranny with a hardened mainshaft from LPE. You will also have to have the front and rear main bearings replaced also asa they will get detroyed on rebuild. If, it busted the rear housing on the case, thats replaceable too, but look at places like Karshop or local tranny rebuilder to get one way cheaper than the GM $300 bucks.
Unfortunately...The diff case if broke is toast..Time to find a donor 3.42 and and put your gears in it.
Phil
Old Sep 22, 2004 | 06:10 PM
vettethret's Avatar
vettethret
Phil
Thanks Phil,
I'm going to rebuild this biatch like the 6 million dollar man!
Old Sep 22, 2004 | 07:07 PM
Patches's Avatar
Patches
Dave
About $100 I think. That's his tranny jack. I'll ask.
To Please Help-broke Tranny....
Old Sep 22, 2004 | 08:06 PM
Mike Mercury's Avatar
Mike Mercury
ding... ding... ding; we have a winner
cool tranny jack
looks exacytly like this one:
Transmission Jack from Harbor Freight: item 39178-0VGA
Old Sep 22, 2004 | 08:20 PM
Patches's Avatar
Patches
I believe that's it, Tim. I think I remember him mentioning our local Harbor Freight dealer.
Old Sep 23, 2004 | 03:45 AM
SLO VETTE's Avatar
SLO VETTE
i can vouch for gene @ karshop. just got a tranny, gears and tc from him recently for install for my--ahem!--busted tranny, gears, and tc...(everything went great on install, a&a did the work).
Phil
