wanna eat vipers
Old Sep 24, 2004 | 06:13 AM
MRC5's Avatar
MRC5
Default wanna eat vipers
my goal is fast street c5 and be ready to beat twin trubo porsche and viperssssss .
. my mod. 98 a4 .
a&a p1sc 7 psi - 42lb injectors -racetronix fule pumb -tb - long tube headers - x pipe - slp loud mouth - z06 intake - 160 thermo. - 3.73 gear - 3200 stall - trans go kit shift - tr6 plugs - msd plugs wire -
what do you think guys ? is it enough to 500 hp ???
what a bout 3.73 gear . is it ok with ati or i should back to 3.42
Old Sep 24, 2004 | 07:22 AM
wrustywrench's Avatar
wrustywrench
I have a 98 a4 with maggie at 5 psi, no stall but shift kit and 373 gears,, I can run with and beat some older vipers, depends on the driver,,,newer higher hp ones are hard to whip one...but you will have more hp than me,, so you might be luckier
Old Sep 24, 2004 | 10:30 AM
brialex42's Avatar
brialex42
I would recommend at least adding a cam that can better maximize the additonal air from the SC. It would not have to be anything radical as even the smaller cams respond well to SC. However with that said, the only thing I would be sure to get is a split duration cam with the intake side that has a lower numerical value than the exhaust side.
To wanna eat vipers
