C5 convertible trunk adjustment ?
Old Sep 25, 2004 | 06:18 PM
lt1george's Avatar
lt1george
Default C5 convertible trunk adjustment ?
Is there any adjustment to make the trunk pop up alittle more ? Thanks. Save the Wave.>George
Old Sep 25, 2004 | 07:39 PM
T_Vert's Avatar
T_Vert
you are supposed to be able to adjust the spring. i did it and it worked great for a day and it was back to normal..
dave
Old Sep 25, 2004 | 07:48 PM
BrentH's Avatar
BrentH
I adjusted the little "bumpers" on my FRC (same deck lid though). It made it pop up more, but a bit harder to close.
Old Sep 25, 2004 | 11:07 PM
Armadillo's Avatar
Armadillo
The original owner of my vert said to squirt some WD 40 down into the latch area from time to time. Was skeptical at first, but it seems to work.
Old Sep 26, 2004 | 03:20 AM
BradSW's Avatar
BradSW
From: From San Diego to Bentonville, AR.....WTF was I thinking?!? Oh yeah, that free state thingy!
St. Jude Donor '15-'16
Dale, thanks. Your WD-40 suggestion did the trick. My trunk only popped up enough to get my fingers under about 10% of the time. I even took it to the dealer and they said they fixed it. NOT! I sprayed a little WD-40 on the latch to night and now it works perfectly....several times.
This forum is the greatest. I learn more about my car here than any place else.
Old Sep 27, 2004 | 09:50 AM
lt1george's Avatar
lt1george
Thanks everybody. The WD 40 did the trick.Save the Wave.>George
Old Sep 27, 2004 | 10:23 AM
slythetove's Avatar
slythetove
White Lithium grease would be better than WD40 by the way.
Old Sep 27, 2004 | 07:07 PM
vettenuts's Avatar
vettenuts
I found that this problem occurs due to the rubber weatherstripping. If you adjust the stops you are putting some load on the trunklid. Just put some silicone on the weatherstripping and it will pop right up again.
Old Sep 27, 2004 | 07:51 PM
lt1george's Avatar
lt1george
Default trunk adjustment
Thanks again for all your help.Save the Wave.>George
To C5 convertible trunk adjustment ?
