6spd Problem Pops Out Of Reverse
Old Sep 28, 2004 | 07:57 AM
66vette's Avatar
66vette
Default 6spd Problem Pops Out Of Reverse
Car drives perfect, no issues at all. One glitch is when you go to backup, you have to hold it in gear with one finger or it jumps out. Do you have any ideas other than to pull the trans? I already checked the shift boot, no problem. thanks.
66vette
Old Sep 28, 2004 | 08:14 AM
ThissenW's Avatar
ThissenW
This is typically the result of worn gears. It usually gets worse over time.
Old Sep 28, 2004 | 04:00 PM
steve badalamenti's Avatar
steve badalamenti
Very common problem. 99 % of the time I need to double-clutch
to reverse. Or, you can try touching another gear first before you slip
it into reverse. It should stay in then without you holding it.
If not, before I spent any real heavy bucks, I'd fiddle with the
linkage in the chassis tunnel first. Likely something simple.
Old Sep 28, 2004 | 04:32 PM
SR71's Avatar
SR71
I had the same problem untill I had to upgrade my clutch. the dealership mechanic readjusted my shifter and it has been flawless ever since.
Old Sep 28, 2004 | 04:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you have a service manual? There is a shifter/shift linkage adjustment that you can follow. I bet you that that is what the problem is.
I also changed the tranny fluid in my 98 Coupe and on my ZO6 to Mobile 1 Synthetic. Man did it make a difference in shift smoothness!
Try the shifter/linkage adjustment and at least change the fluid to see if that helps before you spend the money to rebuild.
BC
Old Sep 29, 2004 | 10:41 AM
cire96's Avatar
cire96
I had the same condition. Unfortunately all of the preceeding attempts failed to correct the problem. The transmission had to come out and the reverse gears replaced.
The reverse gear set on the C5 is VERY small. It behooves the driver to be VERY gentle when putting the car into reverse since the gears (about a half inch wide) will not take many "rackings" and still keep the square cut required to stay in gear. Hope one of the cheap fixes works for you.
Cire
Old Sep 29, 2004 | 10:52 PM
66vette's Avatar
66vette
Default Thanks Guys
But No Luck Had To Pull Trans And Put New Reverse Parts In .
66vette
To 6spd Problem Pops Out Of Reverse
