Best O2 sensor?
Old Sep 28, 2004 | 08:38 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Best O2 sensor?
Well any suggestions? Mine just took a dump , so looking for another set. Heads/cam/headers/no cats car.
Old Sep 28, 2004 | 08:43 PM
LoneStarFRC's Avatar
LoneStarFRC
I went with Bosch when I needed them. JMHO
Robert
Old Sep 29, 2004 | 12:16 AM
TNTC5's Avatar
TNTC5
Default o2 sensors
The new DENSO O2 sensor for c5 should do the trick. These new o2 you can run fuel additive or race gas without any issue for me anyway. Everytime i ran race gas with stock o2 or bosch sensor the code were my biggest issue. After 6 months with DENSO no problem at all. I hope this help you guys.
Old Sep 29, 2004 | 12:47 AM
Richin Chicago's Avatar
Richin Chicago
http://www.sparkplugs.com has Denso OE identical sensors.
Just fill in the car information and then go to 02 sensors on the pull down menu right under the car description near the top of the page.
Old Sep 29, 2004 | 06:25 PM
LoneStarFRC
Hmmm.... good info thanks. I'm not running race fuel but this is good to keep in mind for future mods. etc.
Robert
Old Sep 29, 2004 | 06:31 PM
GTC's Avatar
GTC
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
My front right o2 sensor threw a code recently, but it has settled down for the moment. I may need some new ones soon. It is hardly stock; I think that the o2 sensor may be the only stock part of my exhaust!
Old Sep 29, 2004 | 08:08 PM
jfrc's Avatar
jfrc
i put some gas additive in to clean system before i dissasemble the heads this winter. it was not even a 1/8 tank into and my O2 codes started hitting. I reset them, but they return. The tank is almost empty, so i will see if a fresh tank will cure, if not, the Denso's might be next.
Old Sep 29, 2004 | 09:18 PM
BHP's Avatar
BHP
GM uses Denso's on newer C5/C6. It is supposedly a better unit per a GM contact.
Old Sep 30, 2004 | 04:32 PM
BlueRag's Avatar
BlueRag
Default Denso OE Fit O2's
I just replaced my stockers at the recommendation of LAPD's tuner, and the Denso's work great My C5 feels like it got a tune-up, and runs smoother at WOT I puchased them from sparkplugs.com.......
Old Sep 30, 2004 | 08:09 PM
jfrc's Avatar
jfrc
which one did you get? the exact replacement or the generic model, because there are some price differences there
Old Oct 1, 2004 | 12:22 AM
BlueRag's Avatar
BlueRag
Default OEM Denso's
I purchased the OEM replacements #234-4012 $43.98 ea. They have the correct harness connector and plug right in. I pulled 398rwhp with one O2 sensor on it's way out, and now my 01 Vette runs awesome with the new Denso's
Old Mar 30, 2023 | 02:57 AM
a_ahmed's Avatar
a_ahmed
Sorry to resurect this thread but what is the PN for Densos? There's three listed
Denso 234-4000 Universal Oxygen Sensor
1 in stock
Order by 12pm PST M-F for same day shipping
SKU: #234-4000
ITEM: #DEN234-4000
POSITION(S): UPSTREAM, DOWNSTREAM
INFO: O.E. Quality Universal Replacement Sensor
QTY REQ. PER VEHICLE: 2
Compare$57.13 $45.70 USD
Denso 234-4012 OE Identical Oxygen Sensor
9 in stock
SKU: #234-4012
ITEM: #DEN234-4012
INFO: O.E. Quality Replacement Sensor
Compare$31.64 $26.93 USD
Denso 234-4617 OE Identical Oxygen Sensor
4 in stock
SKU: #234-4617
ITEM: #DEN234-4617
POSITION(S): DOWNSTREAM
Compare$52.07 $41.66 USD
Old Mar 30, 2023 | 11:36 PM
SilverC54me's Avatar
SilverC54me
Use the AC Deloco AFS75 for the upstream (pre cat). I have had issues with anything else.
Gary
Old Mar 31, 2023 | 02:50 AM
a_ahmed's Avatar
a_ahmed
Ah I ended up ordering x2 Denso #234-4012 from Amazon.ca!
To Best O2 sensor?
