Climate Control screen is dim, normal?
Old Sep 30, 2004 | 06:43 PM
mitchydkid's Avatar
mitchydkid
Default Climate Control screen is dim, normal?
Hey guys,
I've recently got the bug to fix those little things that bug me. Other than the AH issue I have already posted about, I would like to know if there is a way to make my dual zone climate control digital screen brighter. The screen is very dim and almost impossible to read during the day time. Does anyone else have this issue? Any known fixes?
Thanks,
Dale
Old Sep 30, 2004 | 06:55 PM
rob&dalevance's Avatar
rob&dalevance
I had this same problem. Eventualy mine became intermittant, and would display when it felt like it. Anyhow, I went to the dealership and bought a new control unit for 260. I was told on the forum a while back that was the only fix. Ops check good!!!
Good Luck!
Old Sep 30, 2004 | 08:37 PM
Ls1Rat's Avatar
Ls1Rat
Old Sep 30, 2004 | 11:03 PM
LivinTheDream's Avatar
LivinTheDream
I have the issue too, just started a few weeks ago. I've got about 13K more on my extended warranty so I'll wait and add it to the list when I get all the little nagging items fixed. I understand some have fixed it by replacing the bulbs with Radio Shack lamps, which is what I will do if it happens after warranty expires.
Old Sep 30, 2004 | 11:52 PM
Ls1Rat's Avatar
Ls1Rat
you can change some of the bulbs , but the display cannot be repaired with a bulb.
Old Oct 1, 2004 | 07:34 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Dim Climate Control
Originally Posted by Ls1Rat
Try cleaning the contacts between the unit and the plug it is attached to. You will have to remove the center console in order to get at it, but you will have to do this anyway.
If that doesn't work, you can purchase a used one from Gene's Kar Shop. Good luck
Old Oct 1, 2004 | 01:44 PM
mitchydkid's Avatar
mitchydkid
Thanks everyone, sounds like I have a few options.
Hopefully its just contacts.
Dale
Old Oct 1, 2004 | 02:11 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I find that if I punch it hard, it will usually come on for a while. if it doesn't, at least I got to punch it.
Old Oct 1, 2004 | 02:26 PM
klp's Avatar
klp
I've got the same problem and I got similar responses before...it can't be fixed, it must be replaced. I contacted Gene's Kar Shop and he has them for $175 I believe. If a new one is $260, that would be a better choice in my opinion. Since this is a common problem, buying a used one doesn't make much sense if the price delta is only $85. Good luck.
Old Oct 2, 2004 | 10:16 PM
530hp_zo6's Avatar
530hp_zo6
mine JUST went dim on me aswell. but after tapping on the display it got instantly brighter! hopfully this fix is final!
Old Oct 3, 2004 | 06:48 AM
SonnyinVA's Avatar
SonnyinVA
i got a used one at carlisle for $75, works great.
Old Oct 3, 2004 | 03:01 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
The fact that you folks are "fixing" these by taping / punching / beating on the display may indicate a simple refreshing of the contacts (cleaning / reseating) is in order. If you take it apart once, going straight for the component swap, how do you know it was the component vs. the act of disassembly / reassembly?
Old Oct 3, 2004 | 04:36 PM
SonnyinVA's Avatar
SonnyinVA
cuz i tried that first... but couldn't see anything that was obviously out of place/broken/loose.
To Climate Control screen is dim, normal?
