How to replace amber side light next to DRL?
Old Oct 2, 2004 | 09:32 PM
Hirohawa's Avatar
Hirohawa
Default How to replace amber side light next to DRL?
The passenger amber bulb has burned out next to the Daylight running lights.
What kind of bulb does it use and can I install it myself?
Steve
Old Oct 2, 2004 | 09:41 PM
LoneStarFRC's Avatar
LoneStarFRC
Steve
#194 and yes you can. Raise headlights, remove black close-out panel around headlight (three screws), reach down inside fender and turn the socket 1/4 turn counterclockwise. You will be working with one hand but it's not as bad as it sounds.
HTH,
Robert
Old Oct 2, 2004 | 11:13 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
HTH,
Robert
also if you remove the hood adjuster next to the headlamp assembly.. it will give you alittle extra room..Note the position of the jam nut..
Old Oct 2, 2004 | 11:30 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
I reached through the front brake duct myself. I did it in about 5min if that.
Old Oct 3, 2004 | 01:36 AM
Hirohawa's Avatar
Hirohawa
I know you can reach the DRLs through the brake duct but can you also get teh light next to it?
To How to replace amber side light next to DRL?
