Updated Nick Williams 90 mm TB
Old Oct 3, 2004 | 05:28 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Updated Nick Williams 90 mm TB
I had one of the earlier Versions of Nick's 90TB and was very happy with the vast improvement over my stock Tb (drilled).
I was able to recently update my TB to Nick's latest version........what a difference!! Nothing major just an improvement in the nuances.I now have smoother idle transitions and more consistent AFRs (Wideband O2) across the ECT and IAT ranges - at least those I've been able to hit with 80*F weather.
I didn't investigate an upgrade earlier because I thought the old version was excellent. Little did I know!!! ............... Nick my hat is off to you This thing is SLICK!!!!
For inquiring minds- all I adjusted were "IAC Park", "RAF" and Throttle Cracker Airflow". With my narrow 106 LSA, and 33* of overlap, I found it helpful the bump the Throttle Cracker Airflow at lower RPMs and MPH.
Old Oct 3, 2004 | 07:16 PM
pdd000's Avatar
pdd000
Old Oct 3, 2004 | 07:22 PM
'97 C5's Avatar
'97 C5
pdd...everytime you post I look because your avatar is so absolutely excellent!
Old Oct 3, 2004 | 10:00 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Most excellent!
Old Oct 3, 2004 | 10:19 PM
ilcorvettegiallo's Avatar
ilcorvettegiallo
Yep, it is a fine piece!
To Updated Nick Williams 90 mm TB
