17" ET Streets
Is there more than one option for a 17" ET Street?
Is the stock front C5 rim wide enough?
I found the MT ET Street 17", it has a 9.5" tread width, but it looks like an 11" wide wheel is suggested.
The other one I found is a radial, 275 40R17, which is probably what people are running?
You can use 9 1/2 x 17, ZO6 front wheels for ET Streets and the Drag radials. You may be thinking of BFG drag radials using 11" wheels.
http://www.mickeythompsontires.com/strip.html
Notice the fine print about rim width at the very bottom. It says:
Acceptable practice for rim width is tread width plus or minus 1 inch. All dimensions @ 10 psi cold on measuring rim.
The tread width is 9.5 inches.
Are these a good option for street/strip performance for an MN6 with 4.10 gears and about 550rwhp?
I am looking to add a 125 or 150 shot to my cam only setup plus a 4.10 gear set. Would these tires have enough grip?
You have to be careful at that power level as if you have too much grip you are liable start breaking driveline components.
Another interesting choice is the recently re-released Racemaster tires. I wonder if any of the C5 guys have tried these yet? They offer several 16" sizes, two of them are 28" tall:
Size
P. Code
T. W.
S. W.
Dia.
Cir.
Rim
26/11.5-16LT
MHD 03
10.0
11.8
26.0
82.0
10.0
28/12.5-16LT
MHD 05
10.0
12.5
28.0
88.0
10.0
28/13.5-16LT
MHD 08
11.0
13.3
28.0
88.0
10.0
http://www.intercotire.com/html/cheater_slicks.htm
