New owner 6spd rattle off idle
Old Oct 5, 2004 | 10:51 AM
Hall1836's Avatar
Hall1836
Default New owner 6spd rattle off idle
I know this has been discussed before but could'nt find past discussions. When coming off an idle in first gear I hear a rattle which in the past would describe as knock/ping, but have been told this is 6spd "rattle". Vehicle is fine in other gears when under load no rattle/knock/ping. If this is a ping should the knock sensors pick it up and will I get SES or some other code? I'm just worried that I may be doing some damage. If it is 6spd rattle can it be fixed and what's rattling? Should I worry about this?
Old Oct 5, 2004 | 10:56 AM
Stu in CA's Avatar
Stu in CA
Video describes a noise from rear of car (and says ignore it), which I hear, I haven't heard of a rattle up front.
Old Oct 5, 2004 | 11:03 AM
allanlaw's Avatar
allanlaw
Feed it more juice on start-up, and see if there's less rattle. That would indicate the classic MN6 rattle on takeoff. Normal.
Old Oct 5, 2004 | 12:24 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Normal.
Old Oct 5, 2004 | 02:21 PM
jak112460's Avatar
jak112460
Most of that noise is the pilot bearing. I don't like it but it's part of the Corvette experience.
To New owner 6spd rattle off idle
