Could this be an oil filter prob?
Old Oct 5, 2004 | 11:09 AM
chillidog's Avatar
chillidog
Default Could this be an oil filter prob?
I've got a 97, 68K, recently changed oil (mobil 1), and a fram duraguard filter.
I recently noticed I'm hearing what sounds like rocker clattering (or otherwise known as "tappets" that lasts about a minute then goes away.
Could the oil be draining away that bad? and why did I not hear this before?
Pressure seems fine.
Old Oct 5, 2004 | 11:38 AM
papas97's Avatar
papas97
I just did the same thing. Oil change Fram filter. Started the car this morning and had the same thing happen. Had never noticed this before so maybe there is something to do with the filter.
Old Oct 5, 2004 | 04:31 PM
carpe dm's Avatar
carpe dm
What weight oil did you use? The filter may be more restrictive and /or the oil may be heavier than you were using. Sounds like the lifters are a little slower filling.
Old Oct 5, 2004 | 06:06 PM
vettenuts's Avatar
vettenuts
I have been monitoring this situation myself. I have in past years used either the Mobil-1 filter or the UPF-44. Recent test data indicates this filters do not flow cold oil too well. I recently switched to a Baldwin filter. We haven't gotten to the real cold weather yet, but it has been a bit cool and I have not yet had the engine tick. I am becoming more convinced that the oil filter does indeed have something to do with this. It is the same sound you describe, like the lifters are starving for oil. It is not piston slap.
Just do a filter change with the engine warm, fill the filter, run the car and shut down until cold the next day. A new filter will tell you quick if that is where the problem lies. I would be very interested in your findings.
Old Oct 5, 2004 | 06:11 PM
lar66BB's Avatar
lar66BB
Default filter
Pay the extra and get a good filter, K&N has the best flow numbers.
Napa Gold is pretty good for less money. I just don't think much of
the fram filters. You can see cut aways of the different filters at
some of the auto parts stores.
Old Oct 5, 2004 | 09:20 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
It is the filter. That is why GM went from the PF 44 to the PF46 on the LS1. The PF46 has a drain back preventer. I am sure you can get a similar filter from Fram or Mobil 1 if you cross the PF46 filter over.
Old Oct 6, 2004 | 07:33 AM
chillidog's Avatar
chillidog
Thanx guy's, I'll try the filter and let you know...
Old Oct 7, 2004 | 06:27 AM
Patman's Avatar
Patman
The PF44 also has the antidrainback valve too though.
Old Oct 7, 2004 | 07:17 AM
Irish Whiskey's Avatar
Irish Whiskey
Was going roadracing and needed to change oil as well. Needed to get it done!! Autostore did not have the Mobil 1 filter I have been using and had to use a Fram. Oil pressure is higher than normal - do not know if this is related. However when oil gets "hot" the pressure tends to fall into a very normal range. Will let the Fram stay in over the winter and change it out in the Spring.
Old Oct 7, 2004 | 08:16 AM
C5GIVPilot's Avatar
C5GIVPilot
I am having the same tapping problem, just started this week, cold engine. . Sounds like one side one lifter only. Goes away after about 3 minutes and temp rise. 2000 vert., stock internal eng. 24500 mi, 2100 hundred miles scince oil change, mobile 1, 5/30. I will be researching filter options. Thanks for the post.
Old Oct 7, 2004 | 08:36 AM
ZO6vettepilot's Avatar
ZO6vettepilot
Try a different brand filter. Most likely it's the anti-drain back valve. Some filter manufacturers use a better design than others. AC Delco, Mobil1, AMSOIL, WIX are some of the good ones out there. Fram is one with a poor design valve and/or valve material.
The anti-drain valve is supposed to hold the oil in the oil passageways throughout the engine, thus preventing a "dry" startup. If it doesn't hold the oil in the upper portion of the engine, particularly the valve train, then clatter is going to be heard on start-up because of the lack of immediate oil pressure in the lifters.
zo6vettepilot
Old Oct 7, 2004 | 05:46 PM
mountainmotor's Avatar
mountainmotor
There is a TSB out on some of the LS1 engines .
The o'ring where the pick-up tube connects leaks causing lifter noise because the oil leaks down .
You might want to check into that if the noise continues
Old Oct 13, 2004 | 02:49 AM
papas97's Avatar
papas97
Changed out filter with Napa Gold filter and no more tapping.
Old Oct 13, 2004 | 03:01 AM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
Sounds good to me.
Old Oct 13, 2004 | 05:35 AM
vettenuts's Avatar
vettenuts
Great news, glad you found the problem. I believe the Napa Gold is a Wix filter, which is a good quality filter.
Old Oct 13, 2004 | 09:47 AM
sprinter's Avatar
sprinter
What you are describing sounds normal for a colder engine at startup (winter approaching). As the engine warms up, the clearances tighten and tapping noise goes away. Same thing happens with every part in the engine...
If it were an oil pressure or supply problem, the tapping would last less than 10 seconds.
Tappets have their name for a reason...
Old Oct 13, 2004 | 10:01 AM
Dr. Dirt's Avatar
Dr. Dirt
When I first got my 5.3 in the serria (Same design as LS1) I remeber reading about problems with non delco filters causing initial lifer noise on start up. Second, I read a report on filters and Fram (I used to use Fram all the time) had less than glowing reviews including drain back problems.
Long story short, I quit using Fram and lifter tap on start up went away in multiple vehicles, not just my GM's. For your application, I would first replace the filter with a delco and see if the that dosen't cure what ails you. If that dosen't fix it, then go for the more complex solutions later.
To Could this be an oil filter prob?
