New World Record
Old Oct 5, 2004 | 05:05 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default New World Record
Did you think it would be something serious or earth shaking??
consider who you are dealing with here.
OK it's fall.. time to change the thermostat... after gathering the tools
190 stat with o-ring greased
dielectric grease
anti sieze thread compound
10 mm wrench
10 mm socket on torque wrench set at 10 N-m (89 lb in. )
channel locks.
it took 4 minutes 30 seconds start to finish.. with a loss of 10oz coolant..
including resetting the fans to stock settings.. A New World Record for me ....I've only done this ten times before.. and a couple a times for a couple a friends.. just as a teaching experience
Old Oct 5, 2004 | 05:15 PM
boatboatboat's Avatar
boatboatboat
I never heard of changing the temp settings as the seasons change.
Old Oct 5, 2004 | 05:18 PM
C5 Curmudgeon's Avatar
C5 Curmudgeon
I dunno if it's a new world record or not. But I do know who I'm gonna visit if I ever need my thermostat changed!!!
Old Oct 5, 2004 | 06:32 PM
Evil-Twin's Avatar
Evil-Twin
well if your like me... I embrace learning something new...
Old Oct 5, 2004 | 06:46 PM
boatboatboat
I don't understand the logic. Why would a car need a diff temp setting based upon OUTSIDE temps?
Doesn't an engine have a specific temp that it runs best at?
Old Oct 5, 2004 | 06:51 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Some guys love a challenge.
Old Oct 5, 2004 | 07:05 PM
Evil-Twin's Avatar
Evil-Twin
I run a 160 stat in the summer with fans set at 183 on and 176 off.. it keeps the car around 190 /200 degrees for the coolant and 210/220 for the opil teperature when its 90 F + outside.. running a 190 stat in the summer will give you 235/240 coolant in traffic and will heat the oil to 240/260F
a 160 stat when its 30 outside will cause your car to run constantly at 160 which is way too cold for the engine and the oil temp..
I put in the stock stat for the winter and return the fan setting to their original configuration... the car never gets colder than 190.
the ideal temperature for an LS1 is 190/200 coolant, and 210 /220 oil temperature.
Old Oct 5, 2004 | 07:10 PM
yankeevetteconvert's Avatar
yankeevetteconvert
Why not put a piece of cardboard in front of your radiator? 30 seconds.
Old Oct 5, 2004 | 07:46 PM
Evil-Twin's Avatar
Evil-Twin
IM not even going to respond to that question..
Old Oct 5, 2004 | 08:43 PM
Ls1Rat's Avatar
Ls1Rat
I'd rather have a real radiator.
Old Oct 5, 2004 | 08:45 PM
George8211's Avatar
George8211
Old Oct 6, 2004 | 06:13 PM
yankeevetteconvert
WOW! I just set a new record with the cardboard. 22 seconds. The trick is to drive the car on 2 by 10s,makes reaching up there a lot eaiser.
Old Oct 6, 2004 | 08:32 PM
George8211's Avatar
George8211
I live about 10 miles from you. If you would've asked I could've helped you... save you a few seconds.
Old Oct 6, 2004 | 09:54 PM
robvuk's Avatar
robvuk
Default Evil-Twin
I don't understand. If the thermostat is wide open at 160, what does it matter if the outside temp is 40 or 120? Once it's wide open, it no longer matters when the operating temp goes over that. The only thing I can see that would possibly get you a few degrees headstart, is the fan on-off adjustments. And that would just be a headstart situation. If your cooling system can't maintain 190-200, a 160 thermostat isn't going to make a bit of difference.
My car maintains that temp with the stock thermostat, only going above if I'm sitting idling in hot traffic with the AC on. That's when the fans kick in and keep it reasonable till I'm moving again. If you're having a problem there, I'd start with a good radiator flush and make sure the radiator isn't clogged from airflow as well.
Old Oct 6, 2004 | 10:04 PM
Evil-Twin's Avatar
Evil-Twin
THanks so much for your help..I will look into your recommendations, are you an automotive engineer or something?
Old Oct 6, 2004 | 10:09 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
TOO FUNNY
Old Oct 6, 2004 | 10:21 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
No, he just plays one on TV......... Say, I read your original post. Why wouldn't you just put a piece of cardboard in front of the radiator?
To New World Record
Old Oct 6, 2004 | 10:28 PM
Evil-Twin's Avatar
Evil-Twin
a piece of cardboard????? are you serious.. so when it gets wet is will get sucked into the cooling fins of the condensor.. then I will have to pick each piece of dried cardboard from the 40,000 cooling fins of the condensor.. IM driving a $50,000 well tuned sports car.. IM not putting a piece of cardboard where a real option designed to do what I want it to do will work. do you put cardboard up on your windows in the house instead of curtains or drapes?
Old Oct 6, 2004 | 10:29 PM
Evil-Twin's Avatar
Evil-Twin
Originally Posted by Z06GMAN
TOO FUNNY
Gary, I even impressed myself with that ......... your the one who made ME laugh!!!
Old Oct 7, 2004 | 02:04 AM
'06 Quicksilver Z06
a piece of cardboard????? are you serious.. ...... do you put cardboard up on your windows in the house instead of curtains or drapes?
