St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Normal oil pressure?
Sorry if this is a Dupe but I did try the search function first.....
What is "normal" oil pressure?
I think that the minimum is 6-8 psi at idle and 18 @ 2000 rpm.
I'm way above those numbers 22 @ idle and 27 @ 2000 rpm.
Just a little worried since the pressure used to be 32-33 psi @ 2000 rpm.
I'm using Mobil-1 5-30. At 30,000 miles is it time to switch to 10-40 weight oil?
Oil presure keeps droping ... down to 17 psi @2000 rpm
Pressure drops under acceleration....what could be wrong?...hope I wake up soon...
My oil pressure is 30 psi at idle. Something is definately wrong if your oil pressure is dropping when you accelerate. If I were you I would not drive your car until you can find out what is wrong.
