I just ordered Borla Stingers for an 04 ZO6. Can I change stock exhaust with out a lift? I know you need about 3' can you get it that high with a floor Jack? Any tricks? Any suggestions?
I jacked mine up to the second hole on a regular set of 1 ton jack stands to replace my exhaust.
It was a little tight, but definitely do-able.
Just remember the stock centre section with cats and h-pipe can get a little heavy when it's on top of your chest for a while.
Good luck.
When I installed mine I fully intended to pull the stock ones intact. I jacked the rear up as far as I was comfortable and it wasn't enough, so I hacked em off. Wouldn't suggust that with the Ti's....
It can be done with a jack, just depends what you comfort level is....
