Exedy Twin Owners
Old Oct 11, 2004 | 11:03 PM
hydfixer1's Avatar
hydfixer1
Default Exedy Twin Owners
Do any of your clutches rattle in netrual?
Old Oct 11, 2004 | 11:14 PM
hrdtopv8's Avatar
hrdtopv8
If you're talking about the "tin can" sound then yes, but not nearly as loud. Almost non-existent at times.
Old Oct 13, 2004 | 08:09 PM
hydfixer1's Avatar
hydfixer1
Yea like some one banging on bell housing
Old Oct 13, 2004 | 08:39 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
mine is very loud rattling, because i have a big cam, G5X3, but i have loud exhaust so i really not notice it that much, the clutch is awesome, it differently finds any weak points in your driveline
Old Oct 13, 2004 | 08:54 PM
mdhmi's Avatar
mdhmi
Only when the clutch is not engaged. Pretty minor on the grand scheme of things.
Mark
Old Oct 13, 2004 | 08:56 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Man really, I guess my cam and catbacks cover up some sounds
Old Oct 13, 2004 | 09:38 PM
RoadRebel's Avatar
RoadRebel
All multi discs will rattle some.
Basically, when the pressure plate is released,the 2 discs and the center "floater" plates are unloaded and free to move around. This give you 3 discs spining on the splined shaft inside of the assembly, which will rattle a bit
Phil
Old Oct 14, 2004 | 12:36 AM
hydfixer1's Avatar
hydfixer1
Thanks, I have a T-REX cam in my 427 with kooks with a 3" off road pipe and stingers and it idles like you can expect it would, so it rattles pretty good. Just wanted to be sure it was ok. Thanks again for the replies.
Old Oct 14, 2004 | 12:43 AM
BlackMagicC5's Avatar
BlackMagicC5
How loud is the rattle compared to the spec stage 3?
Old Oct 14, 2004 | 08:22 AM
GOOSE JR.'s Avatar
GOOSE JR.
If the clutch is out and the vette in nuetral it rattles a bunch, but the perfofmance makes up for the clutches noise.
Old Oct 14, 2004 | 10:01 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
The exedy duel disks do have some rattles because of the 2 disks but its not that bad..
Old Oct 14, 2004 | 01:25 PM
Madkarter's Avatar
Madkarter
absolutly no rattles on mine.
Old Oct 14, 2004 | 08:30 PM
M396 #00-011's Avatar
M396 #00-011
Mine rattles, but is RPM dependant. If I turn on the A/C while parked w/ the clutch out, it will rattle as the RPM drops while the A/C clutch engages.
Keep the idle RPM's up, and I doubt you'll ever notice it much.
To Exedy Twin Owners
