Bad Motive Gears ????
Old Aug 19, 2004 | 02:10 PM
babala65's Avatar
babala65
Default Bad Motive Gears ????
Is this true did Motive have a bad batch of gears??
Old Aug 19, 2004 | 04:51 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
HUH?
Old Aug 19, 2004 | 06:48 PM
GENERAL ST's Avatar
GENERAL ST
Originally Posted by eamador11
HUH?
Not to mention any names .....a "reputable" Forum vender did a CRAP
jpb installing Motive Gears......Thanks Boys
Old Aug 19, 2004 | 11:23 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
I am a Motive Gear dealer I never heard anything about a bad batch of gears!
Old Aug 20, 2004 | 01:46 AM
GENERAL ST's Avatar
GENERAL ST
IM referring to a vender......installer....
Old Aug 20, 2004 | 07:32 AM
RoadRebel's Avatar
RoadRebel
Actually, I have seen them..the tail end of the last batch of gears (390/410)..Installed from different well known shops. You can usually see the material movement on the face of the gear set.
The typical MO of this is the gears are dead quiet at first, and then around 750-1000 miles they start to scream. Based on what I have seen it looks like a heat treat issue. A lot of them have recently been replaced finally as for some reason there were not any gears available for an extended period of time. I know of 3 now that have been replaced with the exact same setup specs as the defective and have been fine.
Phil
Old Aug 20, 2004 | 08:49 AM
babala65's Avatar
babala65
HUH?
I was told by my installer that the reason why my gears were whinning "It was a bad set of gears from motive" True or ?? I wanted to do some reserch to find out if any other members had the same problem...
Old Aug 20, 2004 | 08:54 AM
gmf's Avatar
gmf
Default How do you know if your A4 is slipping?
Well I have a bit more HP now and I am wondering what signs to look for when the tranny is starting to give. The only answer I have gotten is "You will know". I assume there are variations in how it begins to deteriorate/fall apart. Worst case scenario it won't upshift or downshiftom 3-4 or some other gear, but how about just slipping some where I am losing power. Is there any way to detect this w/o a huge $$$?
I am going to the track this Sunday and a bit of anxiety hoping my latest mods/power are truly realized.
With the weather, trapping 116-118mph is what I am hoping for (mods link below in sig)
Old Aug 20, 2004 | 11:21 AM
JakeL's Avatar
JakeL
I had a bad set of Motive 3.90's about a year ago - started howling after about 400 miles of easy driving.
Replaced them with another set of 3.90's that have been whisper quiet for 15K now. If I recall correctly, they were bought from Corvettes of Houston, and Paul warrantied them for me, and I suppose sent them back to Motive. (Motive themselves being fairly unhelpful through the whole deal)
-Jake
Old Aug 20, 2004 | 03:01 PM
99 The Hard Way's Avatar
99 The Hard Way
I had a bad set of 4.10's. They were dead quiet at first, but at about 800 miles they started to whine and just got worse. DTE did the rear end, and warranty'd them fully- labor & shipping included. I highly recommend them for gearsets. Phil acknowledged the problem & took car of everything- a class organization. He said there seemed to be a bad batch of gears from motive. Scott
Old Aug 20, 2004 | 05:18 PM
JHN272's Avatar
JHN272
I had a bad set of 4.10s too...brand new yet they were warped on some spot
I then ordered from gearsareus.com and they double charged me and wouldn't give me my money back until 3 days later
Old Aug 20, 2004 | 05:31 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
How long ago was this?? -ds-
Old Aug 21, 2004 | 12:50 PM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
His differential was built nearly a year ago now.
In an effort to head-off any possible issues with MG ring and pinion sets now, or in the future, we have recently purchased an RC Hardness Comparator that enables us to now closely monitor gear set and output shaft hardness before they are installed into our differentials. Until this time of this equipment purchase, we relyed on the product from MG to be inspected on their end, but just like anything else in mass production, every individual piece is not inspected piece-for-piece, as this procress would consume far too much time in manufacturing to be finacially viable. MG produces a very fine product, but we take this extra step on our end to verify the RC hardness that is expected with these products as a tighter level of QC~ for if they have a problem, we have a problem...
We have also been cryogenically treating ALL of our gear sets for the past three months as a pre-caution, regardless of the differential's stage of build and the additional cost of these QC efforts has been absorbed internally for our two most common versions of differentials.
Just some cheap FYI folks..
Best Regards,
DTE
Old Aug 21, 2004 | 04:28 PM
2ndVette's Avatar
2ndVette
Phil--that is great news. You do go the extra mile. I am hoping to get my 3.90s back to you for you to inspect soon.
Old Aug 22, 2004 | 01:33 PM
DTE Powertrain
Collections Hold
No problem Mark. Do let us know when they are on their way.
Best Regards,
Phil- DTE
Old Aug 22, 2004 | 02:19 PM
Mike Mercury's Avatar
Mike Mercury
WOW !
Old Aug 23, 2004 | 09:38 PM
babala65's Avatar
babala65
Wow, that sounds like a great concept I wish I would have had you guys do my gear from the get go I droped off my carrier for the gear swap about 3 weeks and still waiting I'm starting to go through withdraws
Old Oct 14, 2004 | 08:37 PM
RandyVettes's Avatar
RandyVettes
Life's Short. Drive Hard.
St. Jude '03-'04-'05-'06-'07-'09
Anyone have any experience with Motive Gear 4.10's from New Era Performance? I bought a set and am having Speed Inc install them. The gears are not setting up right and Speed Inc has done A LOT of these so I trust that they are not doing the install wrong. New Era and Motive Gear are each telling me that the other party is responsible. Niether party would ship another set of gears. To avoid waiting until next week and taking up a bay at Speed Inc with my disassembled 04 Corvette I simply bought another set and am returning the set I bought to New Era. I must say I am disappointed with the customer service at both New Era and Motive Gear.
To Bad Motive Gears ????
