Valve Lash
Old Oct 13, 2004 | 11:00 AM
INTHERED's Avatar
INTHERED
Default Valve Lash
How do you adjust valve lash on a stock LS1 rocker arm ?
Old Oct 13, 2004 | 11:08 AM
Patches's Avatar
Patches
There is no valve lash adjustment on the LS1/6. The rockers are installed to neutral (zero) lifter preload and then sequentially torqued to 22 lb. ft. (sequence is in the service manual) to create a predetermined preload on the hydraulic roller lifters.
There are a couple of aftermarket shaft-mounted rocker systems for the LS1/6 that have the ability to adjust valve lash.
