Need your help, noise ?
Old Oct 17, 2004 | 09:22 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Default Need your help, noise ?
I have a 99 coupe, local dealer has replaced two top engine tensioners & still have the same problem. When you first start the car with the ac on all sorts of chatter,squeaks,vibration, damn noise, thus replace the top tensioner. After the car warms no noise until it cools & you start the engine, ac not on, guess what, no noise ! Help please !
Old Oct 17, 2004 | 09:28 PM
Wisdom's Avatar
Wisdom
To me, it sound like the AC compressor clutch - but luckily I'm not too familar with the Vette systems yet!
- Wisdom
Old Oct 17, 2004 | 09:31 PM
alanh's Avatar
alanh
The AC has its own tensioner and idler pully. Either one of these could be making the noise along with the idler on the main belt. All the pullies are the same little wheel on a bearing, doesn't make any difference if it's is an idler or tensioner.
Old Oct 17, 2004 | 09:37 PM
Jimbad's Avatar
Jimbad
St. Jude Donor '06-'09-'10-'11
I really haven't checked but I think that there are two belts. Try spraying some water on one then the other. If the noise desists you have found where the problem is.
Old Oct 17, 2004 | 09:39 PM
T's's Avatar
T's
After the second trip for the same part, I spoke with the service mgr he said there were two tensioner & two different pulleys any or all could be causing the problem. Ok, then why replace thr same part twice,easy to get to ?
Old Oct 17, 2004 | 09:42 PM
RWhite's Avatar
RWhite
Another trick to find the source of the noise if it is a belt is to use a bar of soap on each belt with the engine running. If it is a belt, the squeak will disappear immediately. I am another believer of the Goodyear Gatorback belt. It solved my noise (no tensioner replacement, etc., just a $24 belt.).
Old Oct 17, 2004 | 09:45 PM
T's's Avatar
T's
They said its one belt & its fine, crap @#%$^& will try the soap, thanks
ooops I mean one ac belt
To Need your help, noise ?
