Down Side to Super Chargers
Old Oct 19, 2004 | 08:43 PM
Bluewaters48's Avatar
Bluewaters48
Default Down Side to Super Chargers
I have a C-5 and want to supercharge it. Other then the cost, what is the down side to supercharging the engine? Will it reduce engine life? Create problems with other parts?
Barry
Old Oct 19, 2004 | 08:51 PM
Shylor's Avatar
Shylor
Modern superchargers are pretty well designed. Unless you use to much boost, cost is the only downside to getting one.
Old Oct 19, 2004 | 08:56 PM
Richin Chicago's Avatar
Richin Chicago
Barry
If you decide to start doing some track days on a roadcourse the supercharger puts too much stress on the engine.
Old Oct 19, 2004 | 09:07 PM
atz06's Avatar
atz06
To get the best of both worlds, a well tuned and low boost SC is the best way to go. I love my P1
Old Oct 19, 2004 | 09:12 PM
DDSLT5's Avatar
DDSLT5
Hah? I would say the day at the track stresses the engine - if the supercharger is well designed (as most are) and the tune is appropriate (as most should be) then there is no problem running the car hard all day long. The myth that forced induction puts undue stress on an engine is an old and well liked one by many misinformed - the highest stress you can put on any engine is running it at or close to its redline - the shearing stress placed on the connecting rods and the piston wrist pins is massive at these high rpm levels - way more stress than running 10 psi of forced induction at 500 rpm lower.
Old Oct 19, 2004 | 10:12 PM
RocketSled's Avatar
RocketSled
Your fuel bill will go up...And you might lose a few points on your license.
Old Oct 19, 2004 | 10:34 PM
mdhmi's Avatar
mdhmi
Pros:
-- Big bang for the buck
-- Lots of fun.
-- Make lots of power and maintain stockness (with stock H/C).
Cons:
-- Expensive initial costs
-- Potential for belt slip
-- Worn bearings / broken idlers / pulleys
-- Additional weight (although I haven't noticed this with my setup).
The list could go on and on with either section but I'm sure you get the idea.
Cheers,
Mark
Old Oct 19, 2004 | 10:38 PM
Z06 Mike's Avatar
Z06 Mike
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Lot's of visits to Discount Tires...
Old Oct 19, 2004 | 10:40 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Tires wear quickly!! A decent D1-SC setup will get loose at 120 mph-
Old Oct 20, 2004 | 01:07 AM
abailey269's Avatar
abailey269
What kind of trap speeds are you guys seeing making 500-550rwhp with these supercharged applications?
Old Oct 20, 2004 | 04:31 AM
Richin Chicago
I have to ask. Have you run a "add on" supercharged car on a roadcourse all day? I can't remember anybody making it. It's usually the auto transmission that has trouble first but right behind that is coolant problems. Also, few good roadcourse drivers, that are at it long run their engines "at or close to redline" repeatedly if they intend to do this kind of actvity on a repeated basis. Come out to the track with us. The C5 with the hood up missing a lot of the sessions, is usually, the one that is supercharged. Just my, "misinformed", 4+ years of instructing.
Old Oct 20, 2004 | 04:48 AM
EFI-1's Avatar
EFI-1
Rich, check the LPE website for ShannonZ06 as he whips everyones *** around the track in his Magnacharged Z, for what looked like all day.
Old Oct 20, 2004 | 05:00 AM
Richin Chicago
I am going to guess he had had extensive work done to the rest of the drivetrain.
Just my personal experience. I have been wrong before.
Old Oct 20, 2004 | 06:28 AM
AU N EGL's Avatar
AU N EGL
I rember a guy like this at VIR this past summer. He had a magnacharged SC in is car. It was very very fast the first morning, Fast the first afternoon. We were passing him the second morning and the second afternoon he was not running.
He never finished a 30 min run and went in early on all runs. Why? he said tooo much heat, his coolent and especialy his oil temp was sky high. Also he waisted two sets of new brake pads and a set of rotors. I think the pads where ZO6 pads.
His big downfall was heat. He said the road course was fun but was going to stick to drag racing, no corners.
Old Oct 20, 2004 | 11:33 AM
gonbad's Avatar
gonbad
Look in the FI section at JBsblownc5. Big time roadracer with a big time Vortech.
Several members of my club in Houston running chargers for road courses with no problems.
Old Oct 20, 2004 | 11:50 AM
BHP's Avatar
BHP
The stock A4 tranny will not last under these conditions. Consider an FLP tranny in your budget for hard driving. You will also need a high cap radiator, oil cooler, and A4 tranny coolers.
Old Oct 20, 2004 | 12:14 PM
kromberg's Avatar
kromberg
You can become the 'Customer of the Month'....... repeatedly
Keith
To Down Side to Super Chargers
Old Oct 20, 2004 | 12:32 PM
DeJay's Avatar
DeJay
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Old Oct 20, 2004 | 01:22 PM
HIGHRPM's Avatar
HIGHRPM
Near redline engine speeds wear out parts faster than lower rpm levels with boost. If your worrying about wearing out your motor prematurely...leave it stock.
Old Oct 20, 2004 | 01:37 PM
2kbluestreak's Avatar
2kbluestreak
No "shearing stresses" on the connecting rods. They are alternatively loaded in compression and tension. I saw a calculation a few years ago comparing the compressive load on the power stroke versus the tensile load due the the piston weight at high RPM. The tensile load and corresponding stress would be the highest. Piston pins are loaded in shear. The engine specs on the 1968 Pontiac 400 showed the material to be 1010 steel. (I don't know if service manuals show this type of detail anymore.) This is a very mild steel with very low strength properties.
