Help... Bad miss
Old Oct 22, 2004 | 01:51 PM
davette's Avatar
davette
Default Help... Bad miss
Last night while just crusing along, the car started to miss badly.
First of all, I determined the cylinder in question is drivers side, second back from the firewall. Not sure of the cyl #. The header pipe is colder than the other seven.
I checked spark. Getting plenty. Shocked myself checking
Checked the plug. Looks fine. Nothing broken. Charcol grey color.
Then I checked the fuel injector. I switched with another hoping the problem would migrate to another cylinder so I could just replace the injector... NOT! Same problem, same cylinder.
So, I've determined is it most likely not a fuel or spark issue to that cylinder.
What does that leave me with? Valve or spring issue?
I am getting NO trouble codes.
I had heads and cam done about six months ago at AA corvette....
Old Oct 22, 2004 | 02:05 PM
My2Dogs's Avatar
My2Dogs
....pop the valve cover off on that side. Sounds like you may have a broken spring or rocker.
Old Oct 22, 2004 | 02:08 PM
My2Dogs's Avatar
My2Dogs
........pop the valve cover on that side. Sounds like a broken spring or rocker.
Old Oct 22, 2004 | 03:40 PM
davette's Avatar
davette
I did a compression check in that cylinder. Just fine.
I've switched the coil pack, wires, fuel injector, and plugs with the neighboring cylinder. Still same problem. :-(
Old Oct 22, 2004 | 07:20 PM
Dave00C5's Avatar
Dave00C5
It could be as simple as a faulty sparkplug. I've seen a used plug from another cylinder repeat the problem when swapped. Don't ask me why but we went through this on my sons f body.
Old Oct 22, 2004 | 07:49 PM
davette's Avatar
davette
Swapped out with a new one. No better. I'll probably bite the bullet and take it to the dealer for diagnosis.
To Help... Bad miss
