Predator Question
Old Oct 23, 2004 | 01:39 PM
50-50's Avatar
50-50
Default Predator Question
Hey Guys (or Gals),
A quickie.
After I bought my '03 C-5 auto, I did a "Predator Tune" and after tweaking the shift speeds & pressure a little, I let it load & have been pretty happy.
This morning I was putzing around in the garage, and checked the settings (almost 2 years later) and noted that the gear/ differential ratio was set to 3.42 instead of the 3.15's I know to be there.
I don't know if that was a default that I didn't change or whether the voices in my head told me to program for 3.42's (I don't think so), nonetheless, I've reset it for the 3.15 ratio.
Question is...since it's raining in Nor Cal, and I only drive the car in rain at gunpoint, is / should there be a noticeable difference?
Maybe another 20 miles per gallon, or track e.t.s under 8 seconds?
Thanks for any input.
Old Oct 23, 2004 | 03:10 PM
G-lock's Avatar
G-lock
Just a bug in the code, my Predator does the same thing, but the code is correct for a 3.15 so my HPTuners shows. Good Luck, Jeff
Old Oct 23, 2004 | 03:29 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by 50-50
Hey Guys (or Gals),
A quickie.
It will make the speedodometer off a little. And question for you, did you have a track # increases with the predator. And dyno #s?
Old Oct 23, 2004 | 03:39 PM
Mike Mercury's Avatar
Mike Mercury
absolutely and positively 100% INCORECT
no speedo error on the C5 with rear axle ratio changes... either real changes or not.
Old Oct 23, 2004 | 03:41 PM
Mike04's Avatar
Mike04
Old Oct 23, 2004 | 04:04 PM
screw991le's Avatar
screw991le
Why is that? How does the computer calculate speed? So if you changes tire sizes, the speedo will be correct? HOW
Old Oct 23, 2004 | 05:09 PM
Mike Mercury
you tell us? You made the statement. Are you sure you were correct? The C5 is a unique beast. Yes; tire size changes will effect the speedo; but rear axle ratio changes won't.
You are guessing... or applying common sense to manufacture a fact. We are not guessing. Spend time to discover where the C5 VSS sensor is located... and it will become all too clear for you.
Old Oct 23, 2004 | 06:11 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Old Oct 23, 2004 | 06:59 PM
screw991le's Avatar
screw991le
Oh sorry I pissed off the all knowing OZ
Old Oct 23, 2004 | 07:02 PM
screw991le's Avatar
screw991le
Ahh sorry the all knowing OZ has spoken, Just as you stated, you tell us you made the statement also and did not give a reason. SO SIUYA
Old Oct 23, 2004 | 08:03 PM
Mike Mercury
I gave you a and you respond as a smart boy. (must be a Kerry supporter )
Old Oct 23, 2004 | 08:05 PM
Mike Mercury
This "speedo error" is a touchy subject here; as we don't tollerate mis-information. And that one happens here too often.
email me if you really want to know the specifics.
Old Oct 24, 2004 | 03:15 PM
Mike04's Avatar
Mike04
My 04 Predator has the ability to change tire size and recal the PCM to take that into account. Not sure if earlier models do. Tire size changes speedo the gears will not by themself.
Old Oct 24, 2004 | 05:35 PM
Mike Mercury
from what I've gathered... all predators will allow Speedo recal when changine tire sizes.
To Predator Question
