Cam tool for holding lifters???
Old Oct 23, 2004 | 04:04 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Cam tool for holding lifters???
Ok, I like these, but they are pricey. Has anybody made a set of these, or what do you use to hold up the lifters while removing the cam with the Heads on? Thanks!
New cam on the way LG Motorsports G5X2 specs:
232/240 595/608 114
Old Oct 23, 2004 | 04:09 PM
IFLUBYU's Avatar
IFLUBYU
Most common method I have read about on here and LS1tech.com is to get 16 Pen-type telescoping magnetic pick-up tools and to bend the pocket clip out and extend down to the lifter and let that hold them.
Never tried it myself, did heads and cam at same time.
Good Luck!
Old Oct 23, 2004 | 04:11 PM
3Vettes@Home
Cruise-In V Veteran
Thanks, yeah I've heard of using those, but wondered how secure they hold the lifters...
Old Oct 23, 2004 | 04:12 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
You use the magnets which I have done or spin the cam with the rockers off and they will all push up.99.9% of the time they will stay up.
Old Oct 23, 2004 | 04:17 PM
3Vettes@Home
Cruise-In V Veteran
Thanks again, this is the info. I will need
Old Oct 25, 2004 | 02:54 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Go get some 5/16" "wood dowel rod" to use instead of the high $$ aluminum ones.
safest way IMO. see here
Brian
Old Oct 25, 2004 | 05:21 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Brian
Wooden dowels are the way to go as brian said, Oil them up before you insert and you are good to go.. 100% chance they won't fall
Old Oct 25, 2004 | 05:45 PM
rob&dalevance's Avatar
rob&dalevance
5/16 wood dowl / works wonders!!
Old Oct 25, 2004 | 07:09 PM
3Vettes@Home
Cruise-In V Veteran
Brian
Hey Brian , Thanks for the info.
and to everyone else
To Cam tool for holding lifters???
