HELP!..Broken bolt between header and exhaust
Old Oct 24, 2004 | 12:28 AM
BradSW's Avatar
BradSW
From: From San Diego to Bentonville, AR.....WTF was I thinking?!? Oh yeah, that free state thingy!
St. Jude Donor '15-'16
Default HELP!..Broken bolt between header and exhaust
OK, you guys have been great helping me with so many things. Now I need a little more help. Today I installed my new ss tunnel plate (great mod), but when I was putting the nuts back on the bolt studs between the header (stk) and exhaust system, one stud broke. The bolts actually were very tight coming off and going on. So tight that it twisted a bolt in half rather than tighten all the way down (nope, not cross threaded, but should have used anti-seize).
Anyway, how difficult is it to replace these bolt / studs? Anyone have the process or instructions? Is it simple or do I have to disassemble the exhaust system again?
Also, the othe two bolts are tight and holding th exhaust on very tight. Do you think it's OK to drive till I get the new bolts and fix it?
Thanks for your help,
Brad
Old Oct 24, 2004 | 12:41 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
I'll give you a replacement manifold at N/C if you want. It may be easier.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old Oct 24, 2004 | 01:47 AM
30yeardream's Avatar
30yeardream
Brad
Brad I have had to replace bolts on almost every install of the BackBone We have done. I have gotten pretty good at removing the broken studs. Since gm backs the with a flanged nut upside down I have used it to remove the broken stud. what I do is use my hand grinder and cut the flanged edging down to equal the nut size which is a 15mm, I them use a socket to remove it. So far it works every time. Of course I would not want to for get the wd-40 to loosen it. Bring it to the shop and we can do it for you. Andy has offered you a whole exhaust manifold for free ansd that is a great option as well. But I can do this in place. Mark
Old Oct 24, 2004 | 09:53 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I too needed to replace several studs after taking the exhaust off several times. I used the nuts that bottom out on the manifold too along with plenty of liquid wrench. Someone posted the size and AutoZone part number of the studs. I'll try searching.
Old Oct 25, 2004 | 02:03 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
That's a great offer!
Old Oct 25, 2004 | 04:55 PM
Fast one's Avatar
Fast one
To remove the nuts without breaking the studs you need to heat each of them red hot first and reheat them again if a lot of resistance is felt on the wrench. Heat and loosen one at a time. Trying to remove these nuts cold even with spray oil is asking for broken studs.
Old Oct 25, 2004 | 05:18 PM
Ruler89's Avatar
Ruler89
http://forums.corvetteforum.com/showthread.php?t=865320
Old Oct 26, 2004 | 05:30 AM
vettenuts's Avatar
vettenuts
Are you talking Propane or something hotter? I only have Propane available and will be removing mine shortly for a header installation.
Old Oct 26, 2004 | 06:16 AM
NotInTheHerd's Avatar
NotInTheHerd
Get Map gas, fits the same as propane bottle and it is considerably hotter than propane. It is available at Home Depot or Lowes.
I have had map gas make larger bolts than exhaust studs glow red.
Old Oct 26, 2004 | 09:05 AM
Fast one's Avatar
Fast one
I used propane and it took about 60-90 seconds to get the nut red hot but MAP gas would be faster. Aim the flame away from things that melt especially wires; placing aluminum sheet or foil over the wires will divert any stray heat away from them. Don't mistake the nut breaking free from the flange as breaking free from the stud, if the stud turns with the nut reheat! Also get the socket on as fast as possible after the torch is removed.
Old Oct 26, 2004 | 10:16 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
There's some good advice here, and I'd like to add one more tidbit. Before heating the nuts, put a dab of anti-sieze on the stud, just below the nut. That way, when you're loosening the nut, it will thread through the anti-sieze, and spin off easier. (the anti-sieze won't burn off and smoke up like WD-40 or Liquid Wrench will)
To HELP!..Broken bolt between header and exhaust
