Do I need an Alignment?
Old Oct 24, 2004 | 11:22 PM
Dirty Howie's Avatar
Dirty Howie
Default Do I need an Alignment?
I am going to wider wheels 18x9.5 front and 18x10.5 rear. Just had Hotchkiss sways intalled. Also will be adding Erradispeed rotors when the wheel go on.
Do I need a wheel alignment with all this??
Old Oct 25, 2004 | 02:47 AM
The Batman's Avatar
The Batman
Probably not. Unless you have clumsy brutes working on your new car, the suspension won't be yanked or banged enough to put it out of alignment with the changes you describe.
When you've put a lot of miles on the car, and need new tires, it might be a good idea to consider a lifetime alignment, though. After tens of thousands of miles on the road (or one bad pothole), the car's alignment might be a little off.
You can get lifetime alignments for $140-$200, which is less than the cost of replacing one tire. Lifetime alignment seems worth it, since it can help prevent tires from being worn out prematurely.
Old Oct 25, 2004 | 06:07 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
IMHO, a car should be aligned after a few thousand miles. Things will settle, and if the car wasn't "right-on" to begin with, the mis-alignment can become even more so. Just my $0.02 worth.....
Old Oct 25, 2004 | 09:40 AM
URNDWAY's Avatar
URNDWAY
I guess I'm old school. I was always taught to do an alignment everytime you put on new tires.
Old Oct 25, 2004 | 10:29 AM
jrose7004's Avatar
jrose7004
I would align!
Old Oct 25, 2004 | 11:26 AM
The Batman's Avatar
The Batman
When you get an alignment, it's the wheels that are aligned, not the tires. The alignment instruments attach to the wheels.
It's suggested you get an alignment when you get new tires, not to align the tires, but because, by then, the car's gone a few thousand miles, and a few speed bumps, and a few steel plates, and a few potholes, and the wheel alignment may be off.
Old Oct 26, 2004 | 12:12 AM
Dirty Howie
For what its worth.....I have 23k miles and the tires have worn COMPLETELY even!!
I did ask at Corvette Garage where I bought the wheel/tire combo with roadforced balancing and they said....no alignment necessary.
But it does seem to make sense to error on the side of caution and get them aligned.
Thanks for the advice.
Old Oct 26, 2004 | 01:54 AM
NSTG8R's Avatar
NSTG8R
not that old school.
To Do I need an Alignment?
