Logjam Install Difficulties (pic)
Old Oct 25, 2004 | 09:21 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Logjam Install Difficulties (pic)
I've run into a snag installing a logjam line converter on my 2002 Coupe. Those of you familiar with it know the COR-HAR harness has a 3 and 4 pin connector on one end, which are supposedly in the passenger floorboard. I can only find the 4 pin harness, indicated with an arrow below.
Where is the 3 pin harness?
Old Oct 26, 2004 | 01:15 AM
BQuicksilver
Anyone?
Old Oct 26, 2004 | 01:44 AM
NSTG8R's Avatar
NSTG8R
i always assumed those connections were behind the H/U ... guess I was wrong.
Old Oct 26, 2004 | 03:00 AM
Speed Trap's Avatar
Speed Trap
I just installed this setup last Saturday. I found the 3 pin connector along side the rocker rail about 8-12 inches rom the location of the 4 pin connector, towards the rear of the car. It was taped to the wiring loom that runs under the carpet along the rocker rail. I had to remove the plastic trim plate that covers the rail, just pull up on it as it is held in by three spring steel type clips. I then had to roll back the carpet from the edge a little bit to see the wiring.
To Logjam Install Difficulties (pic)
