C5 Automatic Tranny
Old Oct 26, 2004 | 09:45 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default C5 Automatic Tranny
The temp on DIC for the my trans registers 167 on the highway and sometimes goes up to 190 when I juice it a bit.
Is the 167 normal and should I worry about the 190
Old Oct 26, 2004 | 09:52 PM
davette's Avatar
davette
Looks normal. Normal cruising temps can vary based on outside temp. Up to 200 is in the normal range. Hard driving may get the tranny temps up to 230 in warmer weather. Anything higher, you start to slowly break down the tranny fluid.
Old Oct 26, 2004 | 10:02 PM
Benpup's Avatar
Benpup
Default Appreciate it Davette
Appreciate it. Thank you for the quick reply.
This is my 14th Vette, but at 60 I never had a newer one with all the bells and whistles and I always had a stick. I just couldn't turn this one down. I appreciate the assistance. Used to build em up from scratch, but I'm getting to long in the tooth. Again I thank you. Might change the filter, gasket, and fluid anyway as I was told it had 20 grand on it. I'd sleep better at night. Thanks again.
Old Oct 27, 2004 | 08:11 AM
Mike04's Avatar
Mike04
Old Oct 28, 2004 | 12:26 AM
davette's Avatar
davette
Benpup,
Enjoy your vette. I usually change my tranny fluid at about 20K intervals. However, I only put 5K a year on mine. More a time issue than a mileage thing for my fluids. Enjoy!
Old Oct 28, 2004 | 07:44 AM
XTrooper's Avatar
XTrooper
As already stated, normal and nothing to worry about.
Old Oct 28, 2004 | 08:18 AM
Mitch C's Avatar
Mitch C
Do yourself a big favor and install a tranny cooler, they are cheap insurance.
Old Oct 28, 2004 | 10:01 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Went to the track last night and after a few passes, my trans temp was 199
To C5 Automatic Tranny
