light on dash
Old Oct 27, 2004 | 01:29 AM
leyzaola's Avatar
leyzaola
Cruising
Default light on dash
need help:
"abs" and "active handling" turns on in my C5 dash at the same time and always keeping on. do anyone has a comment on that?
i´m scared
Old Oct 27, 2004 | 01:28 PM
Tanner's Avatar
Tanner
You need to read the code from the DIC (Driver Information Center) in the dash. See below link for instructions. Then come back here with more information.
http://www.stengel.net/diccodes.htm
Old Oct 27, 2004 | 11:31 PM
leyzaola's Avatar
leyzaola
Cruising
c1225 h
c1228 h
c1235 h..all from traction control module
Old Oct 28, 2004 | 02:20 AM
NLKoerner's Avatar
NLKoerner
Originally Posted by leyzaola
c1225 h
c1228 h
I'm just learning about the C5's. :o
So,
reading from the book it seems you have a bad connector problem.
C1225 LF Excessive Wheel Speed Variation.
para 2.
Conditions for setting the DTC are,
It is set when the brake is not depressed and no wheel speed sensor hardware is present, and the EBTCM (Electronic Brake Traction Control Module) sees a wheel variation of more than 9 mph.
para 5
Check the wiring connectors throughly.
etc, etc, etc.
It seems you have a connector problem.
C1228 RR Excessive Wheel Speed Variation.
same Right Rear.
C1235RR Wheel Speed Circuit Open or Shorted
Different words same thing,
Ignition on, EBTCM senses an open, short or ground to battery.
Same Diagnostic aids.
Good luck, electrical gremlin's are a bear .
Norm K.
Old Oct 28, 2004 | 09:52 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
go in and erase all your codes.
if they come back, then you ahve a problem
Old Oct 28, 2004 | 10:54 AM
Arthur6's Avatar
Arthur6
Default Same problem as me - and others on here
I had the same problem yesterday...
Read my thread... Art
http://forums.corvetteforum.com/showthread.php?t=935313
Old Oct 30, 2004 | 10:58 PM
leyzaola's Avatar
leyzaola
Cruising
i erased all codes, but still appears the 1235 "h" when i drive her again, maybe a faulty connection but i dont know why is still "h" in the code instead a "c"...gremlins!
To light on dash
