Andy (A&A) was doing it for one of his SC configurations to accomodate the intercooler. If I recall correctly, he cut off the lower mounting bracket and welded it back to the frame at another location. I'm sure he'll give you the info if you call
Who has mounted the radiator flat? I heard that DRM did it on one of their cars. Do you need a custom radiator?
Phillip
Andy lays the radiator down but at a apprx 45 degree angle by sliding out the bottom thereby lowering the top to make it easier to run blower tubing etc over the top and fit under the hood, I have never seen one layed completely flat if that is what you mean--
