Quest for 12.0's
Old Oct 28, 2004 | 12:59 PM
Dave-T's Avatar
Dave-T
Default Quest for 12.0's
Currently my C5 has run a best of 12.65 at 111.4mph with a 2.03 60 foot. This was deep staged and with a DA of around -200 feet. If I was normal staged I probably would have run a high 12.5. My car is and auto with 3.15 gears, with a LS6 intake, Kooks headers, vararam, and dyno tuning. I want to be able to run very low 12's. It would be OK if I occasionally hit the high 11's in great air but I don't want to have to install a roll bar. In order to get to the low 12's I am going to change gears and the convertor. What would you guys recommend for gears and the stall. I was thinking of going with 3.42 gears and something like a 3500 stall.
Old Oct 28, 2004 | 01:05 PM
Mike Mercury's Avatar
Mike Mercury
gears with a higher stall TC should be good for .3, at least.
Your 60' times is where you need the most improvement, and gears with TC is exactly the cure for that.
Old Oct 28, 2004 | 01:22 PM
C5JONNY's Avatar
C5JONNY
ss3600 and 3.73's
Old Oct 28, 2004 | 01:26 PM
cyclerage23's Avatar
cyclerage23
Originally Posted by C5JONNY
ss3600 and 3.73's
Old Oct 28, 2004 | 01:48 PM
Face's Avatar
Face
Sorry, I disagree. I went from a SY3500 with 3.15's to 3.73's, and it was only about a tenth difference. Once you install a high stall, gears don't make much of a difference. Only with the stock converter they make a big difference.
If you're stuck on 3.42's, go with the Yank SS3600. The SS series feels very tight. The SS4000 I have now feels about the same as my old SY3500 in terms of looseness. If you can deal with 3.73's, that would make the car feel even tighter. As long as you don't cruise at 75+, 3.73's are fine IMO.
Don't forget, you're going to need some sticky tires now.
Old Oct 28, 2004 | 01:50 PM
Demented's Avatar
Demented
.3? haha Install a SS3800 alone on that combo and it's good for .5-.6 depending on traction. Gears added to that would just smoke the tires all through first gear no question. If you can hook it up 3.90 gears and an SS3600-3800 is good for 1 second. BTW new rules any stock non-engine modified car can run 11.50's at NHRA tracks with no cage.
Old Oct 28, 2004 | 01:54 PM
Dave-T's Avatar
Dave-T
11.50 for time shots only. During competition E-Town still enforces the 12.00 rule.
Old Oct 28, 2004 | 01:57 PM
Dave-T's Avatar
Dave-T
I like the SS3600 and 3.42 combo. However I am worried that this will routinely put me in the high 11's.
What combo were you running when you ran the 11.62 with your stock motor. What was the air like? How did you run in bad air.
Old Oct 28, 2004 | 05:43 PM
Face's Avatar
Face
Yank SS4000, Race prepped trans by Vette Doctors, 3.73's by ECS, CCW drag package, TPIS LT headers w/ Dr. Gas 3" offroad X pipe, VaraRam, Vette Doctors Tuning, NRC 5 point roll bar, removed passenger seat, ported T/B, and B&B PRT's. That's all I can remember. The air was around -1600. I ran low 12's in the summer with the same combo above but with a SY3500 converter and drag radials.
Old Oct 28, 2004 | 05:47 PM
MC TORCH RED's Avatar
MC TORCH RED
yank st 3500 and 3.42's got me .6 tenths with drag radials.
Old Oct 28, 2004 | 08:54 PM
Mitch C's Avatar
Mitch C
I could not agree more.
Old Oct 28, 2004 | 09:37 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Hey Dave, I think the SS3600 and 3.42's are an awesome combo for what you are looking to accomplish
Old Oct 28, 2004 | 09:38 PM
Cruise-In V Veteran
We are having an install special on that combo..
J/K Carmen
Old Oct 28, 2004 | 09:50 PM
tabbruzz's Avatar
tabbruzz
Dave,
You can do it on converter alone. You will just need to choose wisely. Good luck.....Tony
Old Oct 29, 2004 | 07:56 AM
Eric Fischer's Avatar
Eric Fischer
Originally Posted by tabbruzz
Dave,
I agree with Tony. Take the budget approach and install a converter only. If it doesn't get you where you want then go for lower gears.
Also the gear ratio change of 3.15 to 3.42 is an increase in torque multiplication of only 8%. Hardly worth the expense as a good torque converter will net you much more than that.
Old Oct 29, 2004 | 09:35 AM
PurpleHaze98's Avatar
PurpleHaze98
BIG CAM BABY! Thats what I would do.Id throw a cam at it and maybe some gears. With a cam you will be real close to 11's with your set up now. Gears would help though.
Old Oct 29, 2004 | 04:32 PM
G-lock's Avatar
G-lock
Dave,
Tabbruzz-
Which ProTorque do you have, I bought one and I was curious if you liked yours or would you consider changing. Thanx, Jeff
To Quest for 12.0's
Old Oct 29, 2004 | 04:45 PM
Laguna Blu's Avatar
Laguna Blu
I ran a 12.2 @ 116 mph on Nitto street radials. At that time I was running 3.42's with a 2400 stall speed Pro-Torque converter. It can be done without a large converter so that you can keep your "streetability". A 2400 gives the car a ride similar to stock.
Old Oct 29, 2004 | 06:31 PM
Face's Avatar
Face
If you going to do it, do it right the first time. Remember, each time it's $500 for labor alone.
Old Oct 29, 2004 | 07:11 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
12.2 @ 116 is great with that setup. Its what I am running now
