Tranny Cooler Q's?
Old Oct 28, 2004 | 03:52 PM
LRD VDR's Avatar
LRD VDR
Default Tranny Cooler Q's?
OK, I got the largest Stackable B&M Cooler and I am using Aeroquips SS hose and fittings. My Q is that I'm using -06 size fittings and lines which sounds right to me. Anyone see any issues here? Or am I good to go!
Shahram
Old Oct 28, 2004 | 05:02 PM
XPC5R's Avatar
XPC5R
-6 is a good size to use for A4 and M6 coolers.
Old Oct 28, 2004 | 05:53 PM
Pumba's Avatar
Pumba
If you are driving a six speed, I would recommend that you use #8 hose and fittings from the trans to the electric pump. Pumps do not pull fluid very efficiently and can use the lower restriction of the larger lines to reduce flow losses.
From the pump to the cooler and return you should use #6.
Good luck with your installation.
To Tranny Cooler Q's?
