Parking brake doesnt work
common with the C5s... ya need to get the e-brake readjusted.
requires removing rear wheels, calipers (need to breaker bar to loosen a PIA bolt) and adjust the starwheel that controls position of the ebrake drum.
CA Events Coordinator
Your have a broken E-brake handle/ratchet... you will need to replace broken parts either by dealer or call the Kar Shop (forum vendor) for used parts.
When your setup is working again you can adjust the parking brake shoes by removing the rear rotors as others here have mentioned.
VR
VR
