I am looking at buying some used TPIS long tube headers that came off of a 99' Corvette... Will they fit my 2001 Z06? I need to know asap!
Thanks,
Matt
Thanks,
Matt
Should be just the AIR tubing. You can buy the 99 stuff to retrofit from GM, or find them used.
Thanks,
Matt
Only difference is the right side AIR tube. You will need to get a '99 - most dealers have them.
Thanks,
Matt
You may also have to change the dipstick. Some guys get by by bending the old tube in the right spots to fit. The mounting location is different as well as the bolt that holds it down. I did not have to move the O2 bung, but did have to modify the air tube system. Scott
