Help with front O2 plug removal
Old Nov 1, 2004 | 05:29 AM
vettenuts's Avatar
vettenuts
Default Help with front O2 plug removal
Pulling apart the stock system preparing for my header installation (QTP Tir-Y's). I have unplugged the O2 sensors, but have been struggling with the removal of the front O2 plug from where it is attached to the frame of the car. Is there a trick to removing it from the frame or do you somehow remove the little grey piece that is in the frame from the plug itself?
Thanks for any help, I'm sure more dumb questions are to follow as I progress with this installation
Old Nov 1, 2004 | 05:45 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I've had my motor out three times now and I've broken both of the little gray pieces. I can't remember exactly how the gray piece attaches to the O2 sensor plug, but I remember it being a complete PITA to get them off. Neither one survived all three removals.
I still have the part of the gray piece that sticks into the frame and I have my O2 sensor plugs zip tied to the gray piece to hold them in place.
Good luck with yours and sorry I can't remember exactly how they attach to the plugs.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 1, 2004 | 08:11 PM
vettenuts's Avatar
vettenuts
Well, after didling with it a while, I figured it out. What a PITA. Got one apart and will get the other tomorrow night. Thanks for the response.
Old Nov 1, 2004 | 10:33 PM
RoHo's Avatar
RoHo
Come on now Vettenuts don't leave us in the dark, how did you get it out? I'm getting ready to put on headers and will be going through the same thing.
Old Nov 2, 2004 | 05:16 AM
vettenuts's Avatar
vettenuts
I actually left the grey piece in the frame. If you look closely at the grey piece attached to the black plug, you will see that if you carefully pry the two apart near the opening of the plug, the black plug will slide off of the grey piece holding to the frame. I got one done last night, and found there is a tab holding the grey on just like when you disconnect any electrical connection on the car. I sure hope this makes sense
Old Nov 2, 2004 | 10:02 PM
RoHo's Avatar
RoHo
Thanks for the info, it will give me a place to start, half the battle on working on one of these Z cars is getting things unpluged.
RoHo
To Help with front O2 plug removal
