Visual difference between LS6 & LS1
Old Nov 2, 2004 | 06:22 PM
matchframe's Avatar
matchframe
Default Visual difference between LS6 & LS1
Is there a visual difference between an LS1 and an LS6?
I will be looking at an engine that is suppose to be an LS6, and wanted to make sure that it is not an LS1.
www.bigdogvettes.com
Old Nov 2, 2004 | 07:25 PM
fdxpilot's Avatar
fdxpilot
Look for the casting number on the cylinder head. LS6 heads should have a "243" on them
Old Nov 2, 2004 | 07:33 PM
cyclerage23's Avatar
cyclerage23
According to another thread I found, the block number should be 12561168.
Old Nov 2, 2004 | 07:56 PM
matchframe's Avatar
matchframe
Thanks!!!
These numbers really help!!
Old Nov 2, 2004 | 08:05 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
2001 and newer LS1's shared the same block though.
The head # is the best tell-tale sign I can think of.
Old Nov 2, 2004 | 08:37 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
FWIW, I was told by my engine builder that the 03 LS6 blocks are heavier than the previous LS6 blocks... He didnt know where they beefed them up (within the block itself) but he knew it weighed more. So in conclusion, the block was built up somewhat stronger than the 01 & 02 blocks. I have an 03 LS6 block in my car now.
VR
To Visual difference between LS6 & LS1
