Oxygen Sensor Anti-Seize
Old Nov 3, 2004 | 07:51 PM
vettenuts's Avatar
vettenuts
Default Oxygen Sensor Anti-Seize
Looking at the service manual, it calls out GM Part # 12377953, which is a special anti-seize for O2 sensor re-installation. Does anyone know of a easily accessed substitute in case the dealer doesn't have this stuff?
Old Nov 3, 2004 | 08:04 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
The dealer should have it. Any "O2 Sensor safe" antisieze will work. Check the label. Good Luck.
Old May 11, 2010 | 05:29 AM
vettenuts's Avatar
vettenuts
OK, resurrecting from the dead. Same question. Dealer anti-seize is $25 so looking for another alternative. The Loctite material I use on the spark plugs doesn't state sensor safe to I am apprehensive about using it. Loctite does make a copper based anti-seize for O2 sensors, but I can't find it.
Anyone find something in a national store like Autozone?
Old May 11, 2010 | 08:57 AM
GUSTO14's Avatar
GUSTO14
I have used Permatex and NAPA anti-seize on these for years and never had a problem with removing them years later...
Here are a variety of them in different sizes. A great "tool" to have in the garage.
http://www.google.com/products?hl=en...ed=0CDsQzAMwAA
Good luck... GUSTO
Old May 11, 2010 | 09:36 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Here's what GM shop manuals say about it:
"Important: A special anti-seize compound is used on the HO2S threads. The compound consists of liquid graphite and glass beads. The graphite tends to burn away, but the glass beads remain, making the sensor easier to remove. New, or service replacement sensors already have the compound applied to the threads. If the sensor is removed from an exhaust component and if for any reason the sensor is to be reinstalled, the threads must have anti-seize compound applied before the reinstallation."
I haven't seen any "sensor safe" substitutes for it either. You're probably better off using the GM compound.
Old May 11, 2010 | 11:25 AM
vettenuts's Avatar
vettenuts
Loctite and Permatex list a copper anti-seize for O2 sensors. Spoke with Permatex, the compound is the same as the old Fel Pro C5A that we have at work. Plan to use this. NAPA also carries this material under their part number but provide no technical details for its use.
Old May 11, 2010 | 12:01 PM
Quicksilver Vert 01
NAPA/Permatex (Item# 765-1674) Anti-Seize Lubricant seems like it's also suitable for use.
It states this on the backside of the container, along with some other uses: "For use on spark plug and oxygen sensor threads".
It conforms to MIL-A-907E
Old May 11, 2010 | 02:58 PM
vettenuts's Avatar
vettenuts
Yes, that's it. I have C5A which is basically the industrial call out of the same stuff.
Old May 11, 2010 | 04:27 PM
PSU 98's Avatar
PSU 98
I use a tube of copper-based stuff from AutoZone. I've never had any issues with the O2s or plugs. I never even knew there was a "special" dealer kind
Old May 17, 2010 | 01:03 PM
Quicksilver Vert 01
As long as the the compound that you used remains on the sensor threads, and does not contaminate the sensor element, it should be fine.
To Oxygen Sensor Anti-Seize
