Dimming headlights?
Old Nov 18, 2004 | 01:13 PM
Silver98's Avatar
Silver98
I would suggest monitoring the "Voltage" on the DIC. With the engine off it reads battery volts, with the engine on it reads the charging system output voltage. This is a relatively simple diagnosis to determine the source of the voltage dip. After that, if you throw a meter on the air pump, which should only run on the first ignition cycle, and I've been told, only exists on a MN6 and not on the A4 (clueless why that is!), the air pump should have charged the receiver enough to get the lights up and down once, MAYBE twice.
Just my $.02
