Dimming headlights?
Old Nov 4, 2004 | 07:55 AM
Frankie2blue's Avatar
Frankie2blue
Default Dimming headlights?
Went for a ride last night and noticed the headlights dimming from time to time for no apparent reason. They would just dim for a second or so and then come back to full strength Almost like an electrical drain somewhere in the car, like maybe turning an accessory on that drained some power.I was on pretty smooth roads and nothing was being changed inside the car. Any ideas about this one? A ground maybe? Thanks.
Old Nov 4, 2004 | 08:04 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I just had the same problem with my 01. At first I thought it was me or a reflection because it happened real quick and usually within a few mile of startup, but then I was on a dark road about 1 mile from my house and it happen and then I noticed it was not me.
I took it to the trusty GM mechanic and after some seraching it came down to my altenator was not functioning correctly. They replaced it and I have not noticed the problem since.
Good luck...
Old Nov 4, 2004 | 11:52 PM
Frankie2blue
Thats interesting. I had a problem a while back that when I shifted under hard accelaration my motor would cut out for a second at the shift point and the dealer said it was a loose ground. That has gone away but I thought I was noticing the headlights dimming back then but I thought it was me. I have also had the "charge system fault" code come up but that hasn't happened in a while. Guess it's time to talk to the dealer. Hate going there.
Old Nov 5, 2004 | 08:56 AM
BrentH's Avatar
BrentH
I have had the charge system fault twice in the past 5 months. My lights do the same thing, but I assumed that it was because the fans were kicking in or some other sort of power drain. I know if I roll the windows up or down, the lights dim too.
Old Nov 5, 2004 | 09:17 AM
Wicked Weasel
I got the same Charge System Fault every once in a while, but the dimming of the headlights really bothered me.
Once the Altenator was replaced I have not had either.
Old Nov 5, 2004 | 07:33 PM
Oldvetter's Avatar
Oldvetter
I had dimming of headlights and dash lights while stopped. It turned out it was just a loose battery connection. I would check this first.
Old Nov 5, 2004 | 07:35 PM
Wicked Weasel
Very good point start with the easiest and work your way around. I would also suggest looking to see how good your battery is. If it is old then you might want to replace it anyway to see if that helps...
Old Nov 5, 2004 | 08:44 PM
2000coupe's Avatar
2000coupe
Me to I thought I was going , and of course the wife says she did not see anything. Now I can start the elimination process. Thanks
Old Nov 6, 2004 | 01:34 PM
TXSTICK's Avatar
TXSTICK
I had the same problem, until the battery shorted out.
It also took out the Alt. Replace your batt.
Old Nov 7, 2004 | 10:53 AM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default same here
I have this prob. as well. My batt. is tight but have noticed two ground scrrews up close to the rad. shroud that are actually rusted!! I keep them lubricated with grease to keep them from going any further. I need to clean them up and see what happens. It is a 98 btw.
Matt
Old Nov 7, 2004 | 11:21 AM
JTS97Z28's Avatar
JTS97Z28
Mine does this to and it drives me NUTS!! It seems to do it fairly often too. About a month ago I received the "charge system fault" warning but havent had that warning since. I cleaned all the connections I could including grounds and battery terminals. Have not had a DIC warning since but the headlights still dim for a sec and brighten back up.
Old Nov 9, 2004 | 09:18 AM
Frankie2blue
Has anyone taken their car to the dealer about this or just searched on your own? All my connections are tight and there is no rust anywhere. Battery seems good. Just seems to be a drain somewhere. I would suspect the alternator, but everything else seems fine and it brings the battery back up if the car has sat for a while.
Old Nov 9, 2004 | 09:24 AM
Wicked Weasel
Frankie2blue - as noted above I took mine to the dealer and they traced it back to the altenator. My symptoms were
1. Dimming lights within a few miles of startup (and then it seemed to get better)
2. Charging System Fault.
When I checked everything out it all looked good to me. The battery was fine and the car said it was charging correctly, but I guess it was not because after the fix I ahve not had the same problem.
good luck.
Old Nov 9, 2004 | 09:34 AM
RutRoe's Avatar
RutRoe
I was told by the dealer that this is a normal condition? They told me, after troubleshooting, that the A.I.R. (?) system is the culprit. I am surprised that no one else has been told this. Or am I just being gullable?
Old Nov 9, 2004 | 06:40 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
This is actually quite true.
My car has the dimming headlight issue as well and it's been that way since day one of purchasing the car new.
I replaced the batter with an Optima battery and it helped but, did not get rid of it completely.
When the air pump turns on at night it apparenlty draws enough power to cause a temporary drain on the system. As the pump cycles on and off the lights go dim then brighten again. There should be lots of info in the archives on this.
Old Nov 9, 2004 | 07:40 PM
Silvervette73's Avatar
Silvervette73
Guys i had this problem and they found out the battery had leaked and ruined the wires. there has been a recall for the battery andthey replaced my battery for free and fixed the wires. no problems since.
Old Nov 9, 2004 | 09:04 PM
GKrenn's Avatar
GKrenn
Mine does the dim on occassion after startup and will sometimes throw a PCM1416. It is the air pump cycling on and off as Z06ufgrad stated.
To Dimming headlights?
Old Nov 10, 2004 | 01:17 PM
Mark S.'s Avatar
Mark S.
Mine has done it since day one...air pump is the culprit...almost 4 years later and with only 10.8K miles, the battery/alternator (knock on wood) work just fine.
Old Nov 17, 2004 | 10:39 PM
TXSTICK's Avatar
TXSTICK
The first year mine did not do that, but then it started. I had the dealer check it out and they said it was normal. At night if I put the windows down the light would dim (this was not the case the year before. I told the dealer and they said it is normal. I started getting the system charge fault, the dealer checked it out and said everything was fine. About a week later the car was dead in the morning. It had worked fine the night before. Got the car to the dealer and they said the Battery was shorted. Picked up the car and the meter did not move off of the 12v mark (normal for my car was around 14v) turned around and went back to the dealer, they replaced the alternator and the car worked fine, no more dimming lights, even if I moved the seat.
Old Nov 18, 2004 | 12:52 PM
FallenWhun's Avatar
FallenWhun
Yeah I'm pretty sure the air pump could be one of the potental causes. Right after my headlights dim I get the check engine light which turns out to be the damn p0410 code.
