Rear End Gear Type
Old Nov 4, 2004 | 02:37 PM
trueblue02's Avatar
trueblue02
Default Rear End Gear Type
I cannot locate the code inside of the glove box but my rear diff is stamped with 2.73. Does this mean that I have 2.73 gears or is it just the size of the rear end.
Old Nov 4, 2004 | 03:04 PM
C5JONNY's Avatar
C5JONNY
Sorry, but if you dont see the code and the rear is stamped 2.73, thats what you have. The 2.73 and 3.15 cases are different.
Old Nov 4, 2004 | 04:57 PM
Mike Mercury's Avatar
Mike Mercury
trueblue02;
you can verify that here:
http://mikemercury.home.att.net/ratio.htm
Old Nov 5, 2004 | 10:00 AM
XTrooper's Avatar
XTrooper
If you want to check your engine speed in 4th gear, here are the correct rpm values.
3.15s
2000 rpm @ 72 mph
2100 rpm @ 76 mph
3.73
2300 rpm @ 70 mph
2500 rpm @ 76 mph
3.90
2400 rpm @ 70 mph
2600 rpm @ 76 mph
I didn't calculate for the 2.73s, but if you're turning less than the 3.15 values then, obviously, you have a taller gear.
To Rear End Gear Type
