Correcting speedo after gear change
Old Nov 5, 2004 | 01:58 PM
Pontiaker's Avatar
Pontiaker
Default Correcting speedo after gear change
Can I do this with a Hypertech programmer or do I have to do some kind of custom program? Going from 2.73 to 3.42 A4 car. Can I drive the car after the gear change without the speedo correction, will the speedo be the only problem or will the shift points be off, anything else? Thanks
Matt
Old Nov 5, 2004 | 03:58 PM
Mike Mercury's Avatar
Mike Mercury
Unlike F-Bodies, the C5 is a unique animal when it comes to MPH detecting. Because of this, there is no speedo error when changing rear axle ratios - across the board on all C5's.
Although changes in rear tire heigth will affect the speedo calibration.
Visit my web page for more info:
http://mikemercury.home.att.net/342.htm
Old Nov 5, 2004 | 04:15 PM
Darkness's Avatar
Darkness
The speedo sensor is on the wheel so no need to mess with the pcm.
Old Nov 5, 2004 | 05:13 PM
fdxpilot's Avatar
fdxpilot
Well, you don't need programming to correct the speedo, But if you go to MikeMercury's page on the link he posted, you will see several other reasons you do need programming.
Old Nov 5, 2004 | 05:19 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
And no, the Hypertech won't do the necessary gear scaling for the change from 2.73s to 3.42s.
Old Nov 5, 2004 | 08:11 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Stay away from a Hypertech to change shift points after a rear end gear change---they are useless.....
Old Nov 6, 2004 | 01:29 AM
Pontiaker's Avatar
Pontiaker
Thank you very much! Thanks to Mike too, great write up on the change process.
Matt
To Correcting speedo after gear change
