voltage fault
Old Nov 6, 2004 | 04:04 PM
CAracer's Avatar
CAracer
Default voltage fault
My car has been sitting for some time. When I turn the key, a message says battery 11.8 volts. Is this just the battery needing a charge?
This a new 04 with less than 4000 miles on it. I hope it's nothing serious.
Old Nov 6, 2004 | 04:36 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
That actually sounds a little high, I would figure it would be 13.0 - 13.5 volts.
Old Nov 6, 2004 | 04:39 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
You actually got a fault? Or, when the DIC went through key on the battery voltage showed 13.8 . That level is actually pretty good for a car that had been sitting.
Old Nov 6, 2004 | 05:30 PM
CAracer's Avatar
CAracer
I'm sorry, it was actually 11.8. The dic says it's charging 13.8 to 14.2
Do you think the battery is just low?
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
13.8 is the mean (average ) votage regulator setting. + - 0.7
when there is a problem with your charging system a "Charging system fault " is displayed.
there is nothing wrong with a 13.8 voltage reading..
To voltage fault
