Wiring help
Old Nov 7, 2004 | 11:20 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Wiring help
Can I use a mirror, like one found in a trailblazer with the autodimming feature, map lights, compass, and on-star.
I want the auto dim, lights and the compass to work.
Can the mirror be wired to my 00 vette with the normal mirror, like the 01 and up vette autodimming mirror can be wired to the older vettes.
Old Nov 7, 2004 | 11:49 PM
JC in XTC5's Avatar
JC in XTC5
Yes, you can retrofit the newer mirrors. They are made by Gentex: http://www.gentex.com, and you can purchase the mirror from Mito: http://www.mitocorp.com/nvsmirro.htm.
Mito will be able to provide the information to wire the new mirror.
Old Nov 8, 2004 | 08:32 AM
screw991le's Avatar
screw991le
I want to install a GM mirror, from another gm car, not a gentex, not a donnolly, a GM mirror, I wnted to know if most of the wiring was the same.
Old Nov 8, 2004 | 08:29 PM
Scotty3's Avatar
Scotty3
I used a mirror from a 2004 Corvette that has the auto dimming feature but it dosen't have a compass.You will have to splice 4 wires and the splices comes with the connector.
Mirror GM part # 10433960
Connector GM part # 15306078
Old Nov 9, 2004 | 03:31 AM
markcz's Avatar
markcz
This link may help you out
http://www.c5forum.com/diy/electro_mirror.php
To Wiring help
